Knock Sensor Code
Old Jul 9, 2004 | 08:27 PM
GLEtotehMAX's Avatar
Knock Sensor Code
while i was driving around, my CEL came on. so when i got home i did the self diagnostic and it was a 0304. i was reading a little while ago that that was a knock sensor code. i was just wondering if that needed to be replaced or if something else tripped it.
Old Jul 11, 2004 | 11:08 AM
Nubianmax's Avatar
It needs to be replaced, like under forum how to's
Old Jul 11, 2004 | 07:16 PM
f550maranello2's Avatar
just be a man and put a 470K ohm resistor like i did it solves the problem untill you get a new knock sensor
Old Jul 11, 2004 | 07:23 PM
nissanfreak's Avatar
The knock sensor doesnt illuminate the check engine light. Something else has to trigger it. Possibly an oxygen sensor. Someone correct me if im wrong.
Old Jul 11, 2004 | 08:26 PM
bluestealz's Avatar
Jacked Up off MountainDew
i've read numerous times on the org that the knock sensor doesnt trigger the CEL. the code comes up but is usually because of a bad 02 sensor.... goto jerry rome nissans website if anything and get em. dont forget the "maxima" discount code. i got the bosch at around 75 a pop......maintenance sucks...im actually going to put them on tommorrow because ive been too busy, but now im tired of losing gas and having to smell the gas burn differently
did u just install anything like a y-pipe? could be a possible leak triggering that too. i would also suggest unplugging your battery over night so u can reset the ecu. the light will probably be off when u hook back up the battery, but wait a few hours...if the light comes back on...id go wit 02 sensor
Old Jul 11, 2004 | 09:07 PM
No, i havent put on a y-pipe, but i did install a CAI pretty recently but I dont think that that would have anything to do with it. But ill try to check out both the knock sensor and the O2 sensor.
Old Jul 12, 2004 | 01:36 AM
Timz96SE's Avatar
Just go to Radio Shack and put a 470ohm Resister.
All the Resister does is keep the car from retarding the timing.
But only use 93 Octane, even though your supposed to any how.
You don't want a knock with out a knock sensor. If you have mods like intake exhaust. The mod is great. Because your knock sensor will hear the extra noise under your hood and think its knock and retard your timing. So do yourself a favor find the wire connector going to the knock sensor wire, and put the resister there. peace
This is just info to help you out, Im not responsable for you doing this mod.
It works great for me.
Old Jul 12, 2004 | 05:48 AM
Kevlo911's Avatar
Kevlo for President
470K resistor
ballerchris510
Sep 23, 2015 08:46 PM
homeofbacon
Sep 23, 2015 07:17 PM
ac max 92
Sep 17, 2015 07:35 AM
