'97 GXE - Antenna doesn't go down
Old Apr 2, 2001 | 09:57 AM
gcruse7
I just bought a '97 Maxima GXE and discovered that the power antenna doesn't seem to work. Is this a common problem? Is it most likely the antenna motor or perhaps a blown fuse? Any advice would be appreciated
Greg
Old Apr 2, 2001 | 10:07 AM
clee130's Avatar
If it's not going down at all, and you don't hear a whirring sound when you try to lower it, it might be the antenna motor or a fuse.
But if there is whirring sound, it may just be gunk build-up.
Where you live? Is it cold? It's a common problem with antennas not going down when the weather is cold.
Mine was sticking, so this is what I did. Extend it all the way up, sprayed it with WD40, wiped it down to get all the gunk off, lowered it, raised it again, sprayed more WD40, wiped, lowered, raised, a little bit more WD40.
You get the idea.
Post back with more details about the problem. (Whirring? No whirring? Up all the way and then down just a lil? Won't go down at all?)
Old Apr 2, 2001 | 10:13 AM
gcruse7
No whirring sound at all. It was up all the way when I bought it last Thursday and remains there now. I bought it from the original owner here in the DFW, TX metroplex, so it has never seen very cold weather.
Old Apr 2, 2001 | 11:09 AM
CKNY's Avatar
I thought 97+ gxe's didn't have power antennas?
Old Apr 2, 2001 | 11:12 AM
Weasel's Avatar
They do, I have one. It could be in the Security and Convenience package though, b/c I have that.
Old Apr 2, 2001 | 11:35 AM
gcruse7
According to edmunds.com (and my owners manual), the power antenna is part of the standard equipment for a '97 GXE.
Old Apr 2, 2001 | 12:53 PM
xpdw's Avatar
Dude, I am having the same problem. I already bought the part to replace. You probably don't need the motor, you'll just need the stem to replace. I get all my parts from Courtesy Nissan on the web. Give them a call.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
chisam14
Nov 6, 2018 08:56 PM
