Taking off Pinstriping
Old Apr 2, 2001 | 12:33 PM
Canuck's Avatar
My new 99 has pinstriping.
I was wondering if there was an easy way to take it off without damaging the paint?
Old Apr 2, 2001 | 12:44 PM
Jambo's Avatar
FIRST: Determine if your pinstriping is PAINTED on. If it's tape, proceed. If not, then I'm not sure how you get it off.
SECOND: Start with the area near the front corner light, heating up the area with a hair dryer. Slowly pick a corner off and begin pulling backwards VERY slowly, heating as you go. Stop at a couple of inches back. Heat the next 2" or so. Peel some more.
THIRD: Once you get it peeled off this way, you can get some of the icky residue off with either body clay + Meguiar's QuikDetailer followed by waxing (since the clay takes off the wax).
Old Apr 2, 2001 | 12:48 PM
Canuck's Avatar
Old Apr 2, 2001 | 08:11 PM
I30CeFiRo's Avatar
I'm pretty sure it's just a sticker. When I removed the pinstriping off of my friend's car, it was just a sticker and came right off
Old Apr 2, 2001 | 08:51 PM
Ryan93SE's Avatar
mine is painted....
so beware before you start
Old Apr 3, 2001 | 12:45 PM
96SEDriven
WD-40
I too took my sticker pinstripe off and found that a little WD-40 on a clean rag to do the job with out harming the paint. Also was a warm day. Didn't take long at all.
Old Apr 3, 2001 | 01:26 PM
SMX's Avatar
SMX
be careful!! mine was hell! I so far did one side. The sun had bake on the pinstripe so it was not easy to come off. I tried every thing... nothing made it easy.
Old Apr 4, 2001 | 07:26 AM
wicked1044's Avatar
they sell a pin strip remover.. its a rubber disk that goes onto a drill or something. it erases it off the car.
Old Apr 4, 2001 | 07:33 AM
SMX's Avatar
SMX
Hey wicked, where did you see this disk? I want to order one. Like I said I have one side to go!
Old Apr 4, 2001 | 07:46 AM
wicked1044's Avatar
my body shop ordered it. looks like it was about 4.00
you can probably find it at napa or a automotive store like that.
Old Apr 4, 2001 | 09:25 AM
napster
I had a dealer sticker on my wife's passat stuck to the trunk lid. I used the highpower washer at the DIY car wash and it took off the sticker. Then I removed the glue residue with some 3M hand glaze.
Napster
Old Apr 4, 2001 | 11:54 AM
bmfjeep's Avatar
pin stripe removal
I removed the pin striping off of my Dodge Ram using some hot water from one of those instant hot water faucets, I think it heats it to like 190F. I just poured some on and then grabbed the end and slowly pulled it off, mine was a double striper. I then used some polishing compound to remove any residue, now it looks real fine.
Dallas
Old Apr 4, 2001 | 12:25 PM
Canuck's Avatar
Re: pin stripe removal
Dallas
Hey Dallas, I got my Y-pipe in the mail on Tuesday, and the USPS box was torn apart. Not a problem for me, but it could be a problem in later orders from others. Just thought I would let you know. I am gonna put it onthis afternoon!!!
Old Apr 4, 2001 | 12:53 PM
bmfjeep's Avatar
I keep telling Dan he has to double box them, but I think he
was running low. We have some heavy cardboard inserts on order for them which will enable them to take more of a beating, UPS is really hard on them, the Post Office not as bad. Make sure the gaskets are there, if not let me know and I'll send out some new ones. Let me know how it goes.
That really does work on the pinstriping, I just wish Jeep did not clear coat over the pinstripes as I would love to take them off of it too. I like my vehicles solid black.
Dallas
Old Jan 25, 2005 | 11:45 PM
veeinc's Avatar
Hello.
I removed the pinstripe from my car recently.
On one side, I just peeled it off. It was tedious, because the tape kept breaking. But, there was very little sticky stuff left over, and it came off with some WD-40.
On the other side, I used a blow dryer to heat it, as I peeled it off. This is where the nightmare begins.
The heat helped to get the pinstriping off faster, but it left a lot of sticky stuff behind. I tried goo-gone & WD-40, but nothing would get it out. So, I went to AutoZone to try to find something else.
While I was there, some nosy guy overheard me asking for help and told me that Clay-Lube would get it out. He then told me that he would go get some from his "body shop" around the corner. I thought nothing of it and continued looking around.
So, the guy comes back with a little container of some clear liquid and what looked like some clay and starts rubbing it on my car. I told him to stop, and that it wasn't working. He then spreads some on my door and starts rubbing it even harder. After he's done, he wipes off the excess and shows me the white haze he left behind.
I was pissed! I told him off and made him leave.
Now I got all these scratch marks all over the door. It's really hazy white.
Please, someone tell me that there is something that will get the haze out. I'm thinking about using a rubbing compound, or taking it to a carwash to get it waxed and buffed.
Please give me some advice.
Thanks...
Old Jan 26, 2005 | 05:48 AM
sterlingmaxima's Avatar
lol i think he did use rubbing compound and took your clear coat off if that is teh case your scrwed.
Old Jan 26, 2005 | 07:22 AM
Maximeltman's Avatar
what a jakass! i'd go and make the dude pay for it! i suggest that you do also.
Old Jan 26, 2005 | 07:29 AM
Maxima99SE's Avatar
will fly for food
here's what I did...
heated up the pinstripe with a hair dryer and tried to pull it off, what wouldn't pull off I scraped off with a credit card.
after i got the strip off, the goo remained. I used meguiars paint cleaner step 1 to go over the goo and get it off, took some elbow grease to get it off, but I believe it's safer on the paint than wd-40... i would never let that stuff touch my paint... after I got everything off I went back over where the paint cleaner was used with wax... looks perfect
Old Jan 26, 2005 | 07:32 AM
icedout's Avatar
if it is painted?
mine is painted how would you get it off then?
Old Jan 26, 2005 | 07:37 AM
Lumberg™'s Avatar
on this site too damn much
for a painted pin stripe you most likely have to wet sand it or you may try some laquer thinner. thats how we get them off in our detail shop.
Old Jan 26, 2005 | 07:39 AM
icedout's Avatar
looks like i will be giving that a try then thanks.
Old Jan 26, 2005 | 07:42 AM
Maxima99SE's Avatar
will fly for food
have fun fux0ring your paint.......
Old Feb 21, 2005 | 05:13 PM
VTonmymind's Avatar
Mmm, fresh lobster
Easy Off oven cleaner! (the yellow can)
I just did mine and I was amazed how easy it took mine off (no pun intended) I was a bit leary at first, but they came off beautifully with no damage to my paint whatsoever.
Do it on a nice day, so you have the ability to wash and wax your car shortly afterward.
http://www.lexls.com/pinstripes.html#
He recommends letting it stand for 2-3 minutes, but I found myself having to respray it to get it all off. I ended up waiting 5-8 minutes or so and it seemed to do the trick.
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
mpbclutch33
Dec 26, 2015 11:11 AM
