Installed Cone Filter, now car won't go past 3000 rpm
i just installed a cone filter into my 96 max, and just as soon as i started my engine, i got a CEL. so i checked it and it said Mass Air Flow Sensor. when i stepped on the gas, i felt a little rumble and the car just shut itself off. I know its not the battery or the starter, since the car did start. this happened a couple of times. all of a sudden, when i stepped on the gas, i was able to rev the engine, but only up to 3000 rpm. when it did reach that, it would start jerking like it would die. another problem i got was when i tried to reverse, the car would shut itself off again, similar to the first time i started the car. has this happened to anyone else?
The only plug on the MAF unit it self... unless you didnt disassemble it in the first place. oh and on '96 you gotta take the sensor outta the air box and stick it either in the filter through the MAF adapter and the filter its self or some people I think just zip tied it close to the filter.
Originally Posted by phillysmoswantd
ill try that in the morning. i did take apart the whole intake to put in a CAI but when i started having problems, i put the stock parts back on except for the cone...
ok when i installed my intake, i could feel the gas pedal didnt wanna go in all the way, the problem was taht i was blocking the cruize control and gas lines under the hood. make sure they are free. look at intake manifold and see wat im talkin about
well the gas is now stuck whenever it gets to 2400 rpm. im pretty sure the MAF is not working because when i unplugged the sensor, it did the same thing so it has to be the MAF. is there an place out there that sells this cheap or should i head down to the junkyeard?
if your pedal is stuck, make SURE you have clearance where you tightned the throttle body, and open the throttle to wide. sometimes you'll get lazy and just put the screw to close to the Accelerator cable.
Make sure all your vacuum lines are reconected too. Didnt have the clips on tight after installing my intake and they came off while i was driving and the car stalled out. Quite hard to pull over w/o power steering!
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
