kyb-GR2 with Maxspeed springs
Old Jul 22, 2004 | 01:04 PM
p00tan6's Avatar
kyb-GR2 with Maxspeed springs. Does anyone have this setup? Does it keep the wheel/rubber on the ground very good and is the ride quality ok?
Old Jul 22, 2004 | 01:09 PM
p00tan6's Avatar
kyb-GR2 with H&R springs. Does anyone have this setup? Does it keep the wheel/rubber on the ground very good and is the ride quality ok?
Old Jul 22, 2004 | 05:42 PM
BLACKonBLACK98's Avatar
Former Vendor
i have the maxspeed/gr2 setup. it handles pretty well, and the ride is generally decent.
Old Jul 22, 2004 | 06:53 PM
p00tan6's Avatar
You got any pictures? Is decent comfortable? How long have you had that set up?
Old Jul 22, 2004 | 07:23 PM
NYC_Maxima97's Avatar
I have the GR2/maxspeed also and I think they're fine, they handle pretty good BUT a lot of road noise, especially when going into big bumps. Maxspeeds are crappy springs IMO, the coils touch each other on bumos and it makes a lot of noise. if I had the choice I'd certainly get some other types of springs. Like I said the ride is pretty good no complains there, just the noise is very annoying and frustrating
Old Jul 22, 2004 | 07:39 PM
juani's Avatar
Rockin' VK56!!
It's definitely better than stock, but I'd go with some other spring.
like it's mentioned by other member, maxspeed is cheap and crap.
Old Jul 22, 2004 | 07:49 PM
happyricefob's Avatar
V^___^V
on all feedbacks.
Old Jul 22, 2004 | 08:13 PM
2 Da Max's Avatar
nyc max wat springs would u prefer over them since u live in ny?
Old Jul 22, 2004 | 08:50 PM
HybriDSM's Avatar
Ive had that setup on my 97GLE for about a week. Very noticable increase in handling, but its definately not even close to a real suspension. But it fits my needs perfectly. Not trying to make a canyon carver out of it, and dont want it slammed so much I scrape on every bump. It definately eliminates the 4x4 look, and kicks the handling up a few notches, but it is also noticably stiffer than stock, but no where close to excessivly. And the price cant be beat.
Old Jul 22, 2004 | 08:51 PM
HybriDSM's Avatar
oh, and ill get pics tomorrow. I have before pics, ran out of sunlight to get some afters.
Old Jul 23, 2004 | 06:20 AM
endus's Avatar
An atavistic endeavor...
They will blow. Even the AGX's blow. Get Illuminas.
Old Jul 23, 2004 | 06:40 AM
p00tan6's Avatar
Ok since the maxspeed's are crap springs what about H&R springs, the next closes spring to stock?? I think the illuminas are a waste of money for my application. I dont plan on adjusting anything. I just want a good strut/shock to keep the wheel on the road and not be bouncy. Don't you guys think the GR-2's will last a while on H&R springs? OR is the H&R springs too soft for the GR-2's?
Old Jul 23, 2004 | 06:44 AM
p00tan6's Avatar
If the Maxspeeds coils touch each other on bumps what other springs would you suggest? The maxspeed's are stiffer than H&R, the next comparable spring so would I have the same problems with H&R springs because they are softer? Also do you think you might be getting road noise because of your big rims? How long have you had the GR-2's?
Old Jul 23, 2004 | 07:07 AM
p00tan6's Avatar
Do you have the same problem like NYCmax does with the road noise and the spring coils touching each other over bumps? Do you think the GR2's handle the softness of the Maxspeed's good?
Old Jul 23, 2004 | 10:10 AM
Magikone69's Avatar
ill throw out intrax as a suggestion, ive heard alot of good things about intrax, i wish i had my set up cause id let u know how it rides. kyb agx w 2.0 in drop intax. anyone riding on intrax springs
Old Jul 23, 2004 | 10:20 AM
NEW2DAGAME's Avatar
LOL!! Interesting comments. I've had my MaxSpeeds and AGX's for over a year. I'm sitting on 18"s and I havent heard one peep from mine. I also dont drive my car like I'm playing NeedforSpeed, but when I do want to take a freeway onramp pretty hard, I can do it comfortably. I would recommend them. Dont spend more money than you have to.
Old Jul 23, 2004 | 12:01 PM
p00tan6's Avatar
So not a sound from the maxspeeds ey? What is the difference between Maxspeeds and H&R's? They are both ISO 9001 certified. Maybe the material it is made from? Have you experiened any sagging within the year that you had them? I hate spending more money than i have to!
Old Jul 23, 2004 | 12:28 PM
NEW2DAGAME's Avatar
I dont know the difference between the H&Rs and MaxSpeeds. I do know that my a$$ doesn't sag and I have a system in the trunk.
Kevlo911's Avatar
Kevlo for President
Read hte FAQ's on how to keep springs from making noise. Maxspeed aren't hte only ones.
Old Jul 23, 2004 | 01:27 PM
BlueC's Avatar
wat
I have maxspeeds and GR2s, no noise whatsoever. Sounds completly stock. I think its a great setup, made handling much better, eliminated the 4x4 look, and since I have rough roads around here and snow to deal with in the winter, its the perfect setup. Also, i dont have to worry about scraping. Those who have noises, its not because of the brand of springs, its how you installed them. Could even be loose bolts.
I would reccomend the Maxspeed & GR2 setup for those who want to get rid of the 4x4 look, but dont want the problem of scraping and worrying about the winter. Also, it sits very even.
Old Jul 23, 2004 | 06:10 PM
p00tan6's Avatar
Got any pics? How long have you had that setup? I'm worried about the GR2's being cheap.
Old Jul 24, 2004 | 09:37 AM
Jonny98max's Avatar
i just got my Maxspeeds with Gr-2's installed...(thanks to the guys that helped) and they are pretty good....the ride is relatively close to stock but u can definatly notice a difference when it coems to handling....the ride is just a tad bit stiffer than stock.....as for the ride height its not too bad...not too much of a drop but still gets rid of some of the wheel gap....(good for me becuase my b-pipe hangs alittle lower)...overall good setup....not to mention....NOT EXPENSIVE....
Old Jul 24, 2004 | 11:03 AM
p00tan6's Avatar
Thanks for all the replies. When you car settles in it should be a little lower than it is when it is first installed. I'm going to go with the Maxspeed/ gr2 setup!
Old Jul 24, 2004 | 11:33 AM
JOMAN's Avatar
i have the kyb-gr2 with eibachs and i love my ride....and plus i live in sandiego with the wrost roads in the country....the ride is almost like stock but i can take turns at higher speeds LOL
Old Jul 24, 2004 | 04:09 PM
juani's Avatar
Rockin' VK56!!
how long have you been had this setup??
i heard gr2 doesn't match good with eibachs
Old Jul 24, 2004 | 04:23 PM
Gen8888's Avatar
I also have this setup and the ride is very nice. Not too much bounce and rides close to stock. Cornering is increased by a great amount as well. But if you want a closer ride to stock go with Gr2 w/ H+R.
Old Jul 24, 2004 | 04:30 PM
Kevlo911's Avatar
Kevlo for President
The best ride with drop would be H&R springs and Tokico Illumina shocks/struts. And Sub-Frame Connectors. That combo is very expensive, buy would give close to stock or better.
Old Jul 25, 2004 | 10:37 AM
I'm not the only one having problems with noise on the Maxspeeds, and it's definitely not the installation. Before was a lot worse, you can see the paint dissapear where the coils touched each other, this happened on the 2 top coils. I bought coil insulators/wraps from courtesy nissan and the noise has gone down a few notches, there's still some though.
Handling wise I think they're good and they're cheap. But if I had the choice I'd give H+R or eibachs a try. Ride height is pretty nice, although I have to be careful on high driveways since I just put a Stillen lip.
Old Jul 25, 2004 | 12:02 PM
maximaah's Avatar
I've got GR2's and Progress. Ride is stiffer than stock but not jarring, handling definitely better. Went from this:
To this (about 1.25" drop):
About to move my 300ZX rims over to the Max in a couple weeks...
Old Jul 25, 2004 | 03:48 PM
p00tan6's Avatar
That looks very nice Maximahh! I thought progess springs give you a lower drop than 1.25" ?
Old Jul 25, 2004 | 03:57 PM
Kevlo911's Avatar
Kevlo for President
Progress gives 1.7 and 1.5 drop
Old Jul 26, 2004 | 01:49 AM
JOMAN's Avatar
i've had my setup for about a 1 yr now the ride is great cornering is great, but the best thing is my car looks like a sleeper...i'll post some pics when i upload them
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
