Help!!! Installed Reverse Gagues, and tach is stuck
Old Jul 23, 2004 | 06:36 PM
MattMaxima_V2's Avatar
I just installed the reverse indeglo gagues, and everything is fine but the tach. It sticks at around 2000-2200RPM and once you get to about 4000 rpm it jumps up. Its fine till it reaches the 2000-2200RPM area.
What should i do?
Old Jul 23, 2004 | 07:14 PM
venompwr2's Avatar
I had this happen too except with the speedometer. You need to put more double sided tape on the back of the gauge face to hold it flat against the back. Because whats happening is the gauge face isnt flat and the needle is catching on it at that point and getting stuck, so if you make it more flat then the needle will move as it should. Be careful of this happening w/ your gas gauge mostly since it moves so slow...dont think you're getting incredible gas mileage all of a sudden
Old Jul 23, 2004 | 07:18 PM
bigleman's Avatar
Advocatus Diaboli
The same thing happened to my friends mustang after he installed his guages except it was the temp guage, he sat neutral for like an hour with his engine reved until it overheated b/c he was waiting to the car to warm up....
Old Jul 23, 2004 | 10:01 PM
Nope i drove for about 3 hours, the gas gague, speedometer, & temp all work fine. If i take it on the highway and wack it to about 90-100MPH it kicks back in. But when i take it appart i'll tape it down a lil better.
Thanks for the help =D
(im new to this modding stuff, and im on my 2nd 97 maxima. This one is gonna get all the work i <3 Maxys)
Old Jul 23, 2004 | 11:00 PM
joew's Avatar
where is the tachometer wire? thanks.
What should i do?
MaxLife17
Jun 27, 2019 01:37 PM
pktaske
May 6, 2016 07:49 AM
minsbang
Sep 11, 2015 08:48 PM
pktaske
Sep 4, 2015 08:40 AM
A32goldylocks
Sep 2, 2015 06:39 AM
