need template to drill hole in fender for ebay cold air intake
Old Jul 27, 2004 | 07:45 PM
maximalnemisis's Avatar
if anyone has one or a site I could go too and print one out, or one someone could sell me, (for cheap) or maybe some instruction on how too make one thanx I want too try too install it tommorow thanx for any help
Old Jul 27, 2004 | 08:02 PM
joew's Avatar
do you a fax#?
Old Jul 28, 2004 | 05:19 AM
yes and no I have one at my job I would have too be there when it came through and im on vacation. I will go too the local copy joint around here and get there # and you could fax it there anytime
Old Jul 28, 2004 | 08:19 AM
joew's Avatar
i can only fax it from work. i will not be available to fax it on evenings and weekends.
Old Jul 28, 2004 | 09:35 AM
ok I do have a fax machine here at my house I,ll try too set it up and I'll give you the # thanx alot
Old Jul 28, 2004 | 10:21 AM
unixadm's Avatar
You can fax it to me at my work. We process faxes electronically and I can email the .tif to him. Fax: 916-684-5225 attn: David Wambolt
Old Jul 28, 2004 | 11:28 AM
Tyrexx's Avatar
its a 3inch hole
Old Jul 28, 2004 | 07:08 PM
nyeah a 3inch hole what if you mess up? eventhe smartest people who use the most common sense fail; what if I mess up what then a new firewall
Old Jul 28, 2004 | 07:09 PM
thanx unixadm
Old Jul 28, 2004 | 09:04 PM
Saddles's Avatar
how do you mess up a 3inch hole exactly? All you have to do is put a hole in the innards of your quarter panel...even if it is a little big for the pipe, whats it going to hurt?
Old Jul 29, 2004 | 01:38 AM
ogparjay's Avatar
there's already a hole in the fender wall where you have to cut. 3 inch hole is easy to cut when you have the tools.
Old Jul 29, 2004 | 08:02 AM
joew's Avatar
i just faxed to you and did not write down your name. let me know if you need another fax.
when you folks make a .tif, send me one as well.
Old Jul 29, 2004 | 08:18 AM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Can you please fax the template to me too ?
800.794.3237
Thank you!!!
Old Jul 29, 2004 | 10:38 AM
joew's Avatar
you got faxed.
800.794.3237
Thank you!!!
Old Jul 29, 2004 | 10:39 AM
joew's Avatar
i made a mistake earlier. you got faxed. the fax does not have your name on it.
Old Jul 29, 2004 | 10:42 AM
VeeQueue's Avatar
i received it thank you!!!!!
you got faxed.
Old Jul 30, 2004 | 08:00 AM
unixadm can you please e-mail it too me so I can print it out thanx....... harry
Old Jul 30, 2004 | 08:14 AM
Kevlo911's Avatar
Kevlo for President
It's easier if you test fit hte pipe and draw a circle around it.
Old Jul 30, 2004 | 10:12 AM
Seximus Maximus's Avatar
use a compass and draw a 3" hole on sum paper and trace. better yet put the pipe on the stupid firewall and trace it then cut. geez man... easy easy easy.....
~Work smarter, not harder~
Old Jul 30, 2004 | 11:22 AM
Sqard's Avatar
I also need the template if someone can e-mail it. Sqard@optonline.net. Thanks a bunch
Old Jul 31, 2004 | 06:44 AM
my email address is thegilleos@aol.com thanx
Old Jul 31, 2004 | 06:56 AM
happyricefob's Avatar
V^___^V
u don't need a template. i drilled like a 5" square and it worked fine...
Old Jul 31, 2004 | 08:42 AM
yeah I hear ya but I just want a clean cut man thats just the way I am
Old Jul 31, 2004 | 08:48 AM
Kevlo911's Avatar
Kevlo for President
The cleanest cut would be to test find hte pipe and draw a hole around it and cut a 3.5in circle. Like I said earlier. Not useing a template.
Old Aug 2, 2004 | 03:35 PM
kevlo please see post before mine he said he cut a square.....come on man....I want a clean circle cut also he said a 3 inch hole you say 3.5inch and the otherguy before me cut a 5 in sqaure this is why I need one so I can avoid any mistakes
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
