What does a FSTB do ??
Old Apr 3, 2001 | 05:58 PM
matty's Avatar
i was just wondering what a FSTB does and if its worth buying and IF it is hard to install on a 96 se ??
thanks guys
Old Apr 3, 2001 | 06:05 PM
BrianV's Avatar
It does a lot of stuff. The installation isn't too hard, anyone with proper tools can do it.
Umm, basically it does a couple things. First of all, it looks good in the engine bay. Second, it helps to make the chassis more rigid. Finally, most importantly it helps the car track. Under high speed turning the front strut towers tend to flex in towards each other. This has a negative effect on your steering and tracking. The strut bar keeps the car's suspension geometery as normal as it can under high stress situations.
In a nutshell, you'll only feel the difference at the limit. Also, it effects the ride quality negatively. Since you're preveting inward and outward flex, under some sorts of conditions it makes the ride rougher.
Old Apr 3, 2001 | 06:10 PM
DkGrn95SE's Avatar
Installation
Installing the FSTB is pretty easy. You need a torque wrench and I believe a 14 mm socket for your 96. It takes 10-15 minutes tops. I just put one on and it's incredible the difference it makes. Since you can get one for under $50 shipped and the easy installation I'd say it's a must even if you're not considering mods otherwise.
Old Apr 3, 2001 | 06:40 PM
dntree
A few guys in the forum suggested that I buy the cheapest one. Street-Beat has is for $35 if you're not interested in the fancy colors. It works great.
Old Apr 3, 2001 | 06:55 PM
strattao's Avatar
I read all over the place of how people can't believe the difference with their car after they put on the FSTB. I have yet to read one that says they didn't notice anything, or were unhappy. I also just bought the Street-Beat bar. I figure if it doesn't do anything then I'm only out $35.
Not a bad deal if it is as good as everyone says it is.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
2000MaximaSE
Dec 12, 2000 10:35 PM
Nismo87SE
Nov 1, 2000 06:11 PM
josh95se
Oct 16, 2000 06:34 AM
