Stock Bose HU power wire on 97 Maxima not hot?
Old Jul 28, 2004 | 02:44 PM
Indiglow99's Avatar
Ok I was working on my 97 Maxima because the damn Bose HU buttons and display were not working, and the speakers fading in and out, so I pulled it out disassembled it found one of the white female connectors on the black face plate had come off the silicon board, did a soldering job to get it back on and now when I go to plug it into the factory power lead (two prong power wire) the HU won't power up.
I tested the power wire with a multimeter (volt meter) and and am not getting any reading whatso ever I check ALL the fuses in the car and no blown fuses, so I have NO IDEA what could be causing the power lead to be dead. Anyhow ever experience this or have any ideas? If you have any ideas your help is GREATLY appreciated.
Tom
Old Jul 28, 2004 | 05:25 PM
RA030726's Avatar
I'm nutty for Nissans
is the antenna plugged in? which wire are you testing for power? The bose set up is tricky.
Old Jul 28, 2004 | 05:46 PM
Indiglow99's Avatar
I tested just the two prong black cable, which I believe is the power cable, and I also tested it with all three wire harnesses plugged in at the same time, black two pronged cable and the two white wire harnesses that plug in side by side.
Tom
Old Jul 28, 2004 | 08:21 PM
Indiglow99's Avatar
bump to the top
Tom
Old Jul 29, 2004 | 04:18 AM
njmodi's Avatar
Do I get a tax break?
Tom - you tested it with everything hooked back up right? You said you checked the fuses - you might want to swap out another fuse for the RADIO block and see if that makes any difference...
Old Jul 29, 2004 | 06:22 AM
MadChef's Avatar
Check back where you soldered, make sure you didn't cross some connections (i.e. too much solder).
Old Aug 5, 2004 | 06:21 AM
DenimDan's Avatar
I had that same problem, i pulled it out to put in an aftermarket unit because my display didn't work but i decided not to do it, when i put the bose back in it wouldn't power up. I unhooked the negative terminal from the battery overnight and it worked. i think the bose hus might have something in them if you pull them out without disconnecting the battery. it must trip a switch or something that needs to be reset
Old Aug 5, 2004 | 08:02 AM
Indiglow99's Avatar
hmm I might give that a try.
Does anyone know which wire is the power wire, so I can test with a voltmeter? and also which wire in which bundle the smaller bundle or the larger bundle?
Tom
Smiley101
Aug 1, 2024 08:02 AM
schmellyfart
Sep 25, 2015 04:47 PM
Maxilano
Aug 31, 2015 07:33 PM
kirkhilles
Aug 8, 2015 10:53 AM
