Bosch Platinum
Old Jul 29, 2004 | 08:10 AM
99maxk2's Avatar
Bosch Platinum
who has experience with these plugs and are they any good
Old Jul 29, 2004 | 08:18 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
crap get ngk
Old Jul 29, 2004 | 08:49 AM
THT's Avatar
THT
Throbbing member
Only run NGK plugs in the VQ engine; nothing else.
~THT
Old Jul 29, 2004 | 09:07 AM
Brudaddy's Avatar
+1
Only run NGK in the Maxima.
Anything else is crap.
Old Jul 29, 2004 | 10:00 AM
atpham89's Avatar
I have tried Bosch Platinum +4's and they worked like how any other sparks should work. When I switched back to NGK's Coppers, they felt the same when I gased it. No engine problems or engine lag.
Just that:
platinum lasts around 60k
copper lasts around 30k
But the VQ30DE does utilizes NGKs as stock.
Old Jul 29, 2004 | 11:03 AM
ogparjay's Avatar
yea foreal... i had those bosch plat 4 and once i switched to ngk plats i felt a difference.
Old Jul 29, 2004 | 12:21 PM
Brudaddy's Avatar
The reason people say not to use the Bosche, is because they have had troubles with the plugs melting down and causing trouble in the cylinders.
Nissan designed the VQ to run on NGK....they need to be in there.
Get the coppers (BK5RE-11) and save yourself some money. (they are 1/3 the cost of the plats.)
Old Jul 29, 2004 | 01:56 PM
moose54's Avatar
No problem here with the bosch. In the Haynes manual it says to use NGK platinum or equivelant so I don't think it matters. Ngk is just a company just like any other car part it is interchangable just some get the better bid to be called OEM.
Old Jul 29, 2004 | 02:01 PM
Keyser Skoze's Avatar
I had the platnum 4's and im sorry but they suck. They worked nicely in my VW and Ford but not the MAX. The car would guzzle lots gas. Changed them to the NGK coppers and everything went back to normal.
Old Jul 29, 2004 | 02:14 PM
japmaxSE's Avatar
Go Get a Life!
That is very true, a few yrs back I was going to buy bosche 4+ but lucky I got some good advise not to, nissan told me they also had guys with bosche in there max's come in for tuneup or whaterver and they found that those spark plugs caused some severe meltdowns.
{Nissan designed the VQ to run on NGK....they need to be in there.}
Old Jul 29, 2004 | 02:30 PM
killcrap's Avatar
its actually BKR5E-11 nissan part number 22401-50y05
Old Jul 29, 2004 | 02:35 PM
britishBeef's Avatar
wow thats interesting....i used to work on the max b4 i bought it and i put in bosch plat+4..dont seem to have any neg effects? i also used them in a 2000 2.2L 4cyl camry and owner claims better fuel econ by 1-2mpg. It suppose to be a very high qual plug
Old Jul 29, 2004 | 02:37 PM
killcrap's Avatar
with my coppers and y-pipe and frankencar intake i get roughly around 700 kms from full to empty. i used to only get 600kms per tank.
Old Jul 29, 2004 | 02:38 PM
would a plat spk plug really make u guzzle more gas?
Old Jul 29, 2004 | 02:40 PM
my neighbors car (98 GLE) uses denso iridium and likes em. Interesting
Old Jul 29, 2004 | 02:43 PM
Ant96GLE's Avatar
Dont go with anything but NGK OEM plats or coppers, many orgers have had issues with the car running bad.
Old Jul 29, 2004 | 03:08 PM
nitromax's Avatar
i've put about 28k on bosch plats w/no problems. but in the search for more mpg, i'm ready to try the copper ngk next. maybe the bosch plugs stole my mpg..yeah, that's what happened!
Old Jul 29, 2004 | 03:35 PM
atpham89's Avatar
Changing plugs will help your mpg a bit... but it is more on how heavy your foot is....
Because on highways, I managed to get 460 miles on a tank with Bosch Plat +4 (Aprox. 44k already)
Old Jul 29, 2004 | 04:00 PM
99maxk2's Avatar
thanks for the input, i will def. be getting the NGK then.
Old Jul 29, 2004 | 04:13 PM
Brudaddy's Avatar
Whoops....got dislexic (or however you spell it) for a minute there.
Thanks for the correction, killcrap.
Old Jul 29, 2004 | 04:33 PM
vizslak7's Avatar
The problem is the Hanshin Coils on pre 2K1 Maximas. Mitsubishi coils and post 2k Hanshin coils tolerate Bosch plugs, others don't do so well.
Old Jul 30, 2004 | 04:29 AM
lilaclucymaxima's Avatar
Team Ramrod
i have bosch double platinums and i dont feel any difference in power
Old Jul 30, 2004 | 06:24 PM
nitromax's Avatar
changed to ngk coppers today. car has hanshin coils ('95 ), they tolerate bosch plats just fine.
Old Jul 31, 2004 | 12:49 AM
bird89sc's Avatar
i'm sorry, but any bosch plugs suck as$. i started out with ngk's, changed them to bosch plat. 4's , they made my car barely run and much slower. now i'm running denso's and they're performing better than the ngk's. btw all you have to do to find out how bad bosch plugs are is go to a reputable auto parts store and ask around. 3 out of 4 people will tell you you'll have better luck with anything but bosch
Old Jul 31, 2004 | 04:55 AM
deezo's Avatar
I ran my fasted time to date on Bosch +4's. The problem with these plugs mated to the vQ is that there is a slight loss on low end power plus the VQ burns then right up. There have been cases where the prongs had burned right off the plug.
Robert Schneeweis
Jan 11, 2017 06:47 PM
gigabyte
Jan 6, 2017 06:05 PM
jc53
Oct 12, 2015 05:12 AM
Spartan1310
Sep 28, 2015 08:03 AM
DrVee
Sep 4, 2015 12:18 PM
