What is "double clutching" and why would it be done in a Max?
I go on other auto forums and read a bunch of narratives and watch all kinds of videos etc. The one thing that is often brought up is "double clutching" while racing somebody in a straight line. I recently watched a video of an E55 vs. Z06 and the guy in the Z was double clutching supposedly.
Now, double clutching is just that I assume - double clutching. I'm thinking it limits the lag caused by gear switching to some extent, is that correct? Why do it in the first place? How does it help performance? Probably worthless in a car like a Maxima, unless it's heavily modded, am I correct?
Somebody please elaborate more on this.
Ok I just read that. Can somebody explain why you should let off the clutch in between? Normally I just rev match at the same time as I am shifting to whatever gear I'm going into. Is this bad for any reason? What do you guys do?
Thats what i do and ive always done and never had a problem.
It also helps you not loose your inertia.
Watch these vids at The M5 Driving School to learn all you need to know about shifting and launching.
I double clutch all the time, but not when accelerating in a straight line!
It saves wear on the synchros and the gear engagement is also a lot smoother vs just rev-matching alone. It takes a bit of practice, but after you get your brain hardwired for it, it's just as easy as any other shift. I only ground the gears once or twice while I was teaching myself. oopsie.
What's sad is when people say they double clutch when they don't even know what the hell it is, and when that isn't even what they were doing in the first place.
i remember in the fast and the furious, vin diesel saying paul walker was granny shifting instead of double clutching like he should have been...were they just trying to sound like they knew what the were talking about? seeing how you probably wouldnt double clutch in a street race?
You would never double clutch when you're upshifting. There is no point. The only thing it would do in a straight line race is slow you down and make you all jerky.
I double clutch pretty much all my downshifts now, except if I am really pushing it sometimes I will just revmatch. Once in a while if you're a little hot into a corner and trying to heel and toe the downshift it's a little too much to double clutch....but that's what syncros aer for anyway!
The advantage to double clutching is that with rev matching alone, the syncros still have to spin the layshaft up to the new transmission speed, but not the engine. With double clutching, the layshaft *and* the engine are matched to the new transmission speed so there is basically no wear on the syncros and you can get *very* smooth downshifts. You can even downshift into first gear with absolutely no jerk...but it's difficult.
Here's a great site which helped me to understand all this...
http://auto.howstuffworks.com/transmission.htm
and in aprticular start on this page...
http://auto.howstuffworks.com/transmission3.htm
I know how to double clutch, but I usually just rev match. Depends on the setting though.
04-16-2020 05:15 AM
worldwiderecognized
09-30-2015 01:16 PM
