True Or False: Altima Tranny Will Fit Maxima
Old 08-20-2004 | 08:38 AM
Wil's95SE's Avatar
我爱台湾
I read somewhere on the org that someone had replaced their Maxima Tranny with one from an Altima. I know the I-30 will fit but did not know if a Altima's one would. Can anyone answer this cause i need to get one to replace mine and if an Altima tranny will fit that would be great. Also what other year Maxima's tranny would fit a 95?
Old 08-20-2004 | 08:47 AM
BigLou93SE's Avatar
I'm not sure about the altima transmission question. Unless you're talkning about the new V6 5 spd. ones, then maybe. But I know that you can't swap a 4 cyl. altima tranny into our V6's. You can however put trannies in your car from maximas within 95-01, and certain year I30's (I'm not familiar with these).
Old 08-20-2004 | 08:52 AM
mzmtg's Avatar
Minister of Silly Walks
The V6 Altima trans will fit. None of the 4-cyl ones will, regardless of matching model numbers.
Old 08-20-2004 | 10:02 AM
Dementia's Avatar
Hmmm... one would think matching models #'s means they're the same... cause I know they're the same #. Ah well... learn something new every day I guess.
Old 08-20-2004 | 11:55 AM
Silvia's Avatar
i heard quest will fit too not sure thou
Old 08-20-2004 | 11:57 AM
mzmtg's Avatar
The trans model numbers are the same, but they have different bellhousings to fit the KA24 and QR25 4-cylinder engines. Neither of which fits a VQ.
Old 01-19-2005 | 05:51 PM
michaelnyden's Avatar
so would the new V6 altima trannies bolt up to a 4th gen? I think it's the tranny code RS5F51A
Old 01-19-2005 | 05:58 PM
sterlingmaxima's Avatar
I think the proper term is tranny case, or gear bix case not bellhousing. bellhousing is a term used for auto trannys.
Old 01-19-2005 | 06:01 PM
96ItaliaSE's Avatar
il massimi bassi
i think the tranny from a altima will fit a 3rd generation maxima vg engine
Old 01-19-2005 | 07:16 PM
SPiG's Avatar
SomePsychoGuy
Any VQ transmission will fit any VQ Engine. The problem is that the new 3.5 Maximas and probably Altimas too are cable shift instead of having a beam. Converting that is a major PITA. I think the mounts may be different too for the 6 speed and maybe 3.5 5 speed from altima. I do know that the Tranny input will fit fine.
The KA24, VG, and VE may all have the same tranny input. I know the VG and VE share the same but not sure about the KA. That would make a VG30DETT swap easier in some ways for a 240sx if it will fit in the engine bay.
Old 01-19-2005 | 07:23 PM
MaximaSE96's Avatar
Maxima Owner
TRUE all same transmission.....transtarindustries.com.......i had to replace mine
Old 01-19-2005 | 07:29 PM
goodhead's Avatar
what is need to fit a 6sp 2k2 max tansm. in a 4th gen?
Old 01-19-2005 | 07:50 PM
MaximaSE96's Avatar
Maxima Owner
MONEY.....prolly very similar cases
mrc00l88
01-25-2024 02:14 PM
Lakersallday24
06-16-2019 02:35 AM
Supragte
08-12-2015 11:00 PM
altmycar
08-06-2015 05:44 PM
Tanvirkamal
08-05-2015 02:32 AM
