Problem getting into first gear at stop
Old Aug 20, 2004 | 11:18 AM
MadChef's Avatar
Manual tranny...
Here's the situation:
- Car stopped at a light
- In neutral
- Light goes green, I press down on the pedal
- Try to put it from neutral into first
- Can't get it into first, feels like gears hitting gears
- Can't force it in
This happens every now and then, but it's getting more frequent.
The only way I can get it into first, is to:
-Rev the engine
-Let the rpm's drop while apply light pressure (to putting it into first gear)
-Eventually it it will catch
Any ideas on what's going on? Think my synchro's are going?
Thanks guys, good ot have the .org back
ps clutch fluid is filled
Old Aug 20, 2004 | 11:32 AM
Ladzio's Avatar
Yep, that happens and worn trannies, try double clutching before going in first, it should help.
Old Aug 20, 2004 | 12:30 PM
MadChef's Avatar
Yeah, I'm getting worried that it might be my tranny just plain getting old.
Double clutching? Guess I'm going back to the days before synchros lol
Old Aug 20, 2004 | 02:25 PM
image's Avatar
i got the same problem on mine... I noticed on my dads 97 I can throw it in first gear so easily when im like 2-3 mph and stopping.. but on mine.. i have to THROW it into 1st gear. EEEK!
Old Aug 20, 2004 | 02:58 PM
Maximus_95's Avatar
you know whats weird, i have the same problem. and i just got my tranny rebuilt.
what i do is when it doesn't go in, i pull back to neutral, let go of clutch and do it again, and it usually goes in. i thought it was normal, i know it cant be worn already, rebuilt was done about 3 months ago.
Old Aug 20, 2004 | 03:55 PM
Dementia's Avatar
Synchros are shot. My altima did the same thing. Drain your tranny and fill it with Redline MTL. It does wonders. I couldn't put it in 1st gear at a dead stop half the time, now I can get it in while still moving at about 10 mph.
Old Aug 20, 2004 | 05:15 PM
ThurzNite's Avatar
Drain and fill sounds good. I had the same problem and turns out I was low on tranny fluid.
Jae
Old Aug 21, 2004 | 07:05 AM
maximabebe's Avatar
Who carries redline MTL in as far as local stores? Autozone, Pep boys? .... or do i just have to get lucky and stumble over it somewhere?
Old Aug 21, 2004 | 09:14 AM
Flava_24/7's Avatar
Boosted Panda
If you have a VANS auto parts in your area they carry it.
Old Aug 21, 2004 | 01:35 PM
Dementia's Avatar
Only specialty shops in my area carry it.
Try here to search for dealer in your area:
http://www.redlineoil.com/dealers.asp
MTL just stands for Manual Transmisson Lubricant... or something to that effect. They do carry different weights, but MTL is the most common for non-race applications.
Old Aug 22, 2004 | 06:54 PM
MadChef's Avatar
Thanks guys, I will consider draining the tranny.
Old Aug 22, 2004 | 09:10 PM
image's Avatar
Guys ive never even checkout out my tranny.. is there a writeup or something where i can find out how to propery drain and refill it?
Old Aug 22, 2004 | 09:15 PM
GarciaMaxima's Avatar
So MTL will replace my Regular transmission oil?
Old Aug 22, 2004 | 09:25 PM
Nismo3112's Avatar
Custom User Title
Try putting it into 2nd, and then 1st. Should be easier to go in first.
Old Aug 22, 2004 | 09:30 PM
97I30touring's Avatar
I have the same issue, where u feel like you u have to force it or wiggle it to get it into first gear. i just shift around back and forth, it goes in
Old Aug 22, 2004 | 09:47 PM
Dave B's Avatar
Not DAVEB the parts guy
You're feeling the 1st gear speed lock out. It's simple to get around this problem:
Clutch in, nuetral, clutch out, clutch in, quick rev, select 1st, clutch out. I can grab 1st at 20mph double clutch like this.
Old Aug 22, 2004 | 11:14 PM
thisisausername's Avatar
lol, I guess theres something wrong with my tranny then cuz I can addidentally shift into 1st at 40 mph(was trying to get 3rd)
Old Aug 23, 2004 | 06:20 AM
I30tMikeD's Avatar
The 1st gear resistance is kind normal for us at a stop. What dave posted works or what works for me is go into second, then shift into first without releasing the clutch.
Old Aug 23, 2004 | 06:25 AM
wariow's Avatar
or try gonig in reverse then first
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
pjgreek
Sep 9, 2015 09:30 PM
slowlifer
Sep 8, 2015 05:53 AM
