Gotta hit 13s....What is the DR mod?
Hey yawl, i have a 1996 maxima that i am tryin to get down into the 13s if at all possibly and was readin around and noticeing that people were talkin alot about a DR mod. What exactly is the DR mod, lots of people seem to get a lot from it. And if there are any other mods that can be suggested to get me down into the 13s if not closer please suggest.
mods so far...
Zex wet kit(75hp jets)
Headers and Y pipe
streight through cat test pipe
catback exhaust system
short ram intake
mods so far...
Headers and Y pipe
short ram intake
u a stick? need to plant the power down to the ground also. a racing clutch and a lighter flywheel would help plant the power. never heard of the dr mod. lighter rims will increase times but not that much and suspension get that for the twisties.lol. thats what i would do cause u dont drive in a straight line. ohh and brakes so u can stop the beast.lol
the "dr mod" is the drop resistor mod for sutomatic trannys, it helps a ton in fast fast fast shifts also if your lucky youll sqweel into 2nd gear like the 5 speed boys. basically it just splices wires into your trannys line pressure solinoid and when a switch is activated it cancels the signal to the tranny which automatically makes it have full line pressure on shifts. of course if you use this while not at wide open throttle youll deff f*ck som **** up. i have this mod done and LOVE IT!!! its awsome the way it shifts while on it just throws u back like your stick or somthing and suprises the h*ll out of all my passengers and makes them hit there heads on the seat LOL if yer automatic and want more info im me on aim im on alot otherwise talk to one of the many fellow maxima owners that has done this.
He means the Drop Resistor mod... it makes the auto tranny shift at full pressure making it shift VERY hard. Improves 1/4 times and saves the clutches inside the transmission but its pretty hard on the drivetrain
just get the VBmod, you should be easily hitting 13's with a shot of nitrous... I hit 13.7 with a 50shot awhile back.... Only mods:
VBmod
UDP
Y-pipes
CAI
2.5 exhaust piping
15inch rims
I'm going 5spd thou, I want to be able to hit 14.3 consitent all motor. then go boosted... Good luck thou
VBmod
UDP
Y-pipes
CAI
2.5 exhaust piping
15inch rims
the valve body mod is also pretty much the same thing as the drop resistor but safer cause it actually does somthing physically to yer tranny aka new valvebody. only downside to that is the cost i believe its like $400+ vs $8 for the wire and switch from wal-mart for the DR
Sounds like a neat mod, is it bad on your tranny? How hard is it to set up something like this. Does anyone have a link to a page or something that explains how to do something like this? thanks
Originally Posted by meccanoble
a 75 shot of wet with y-pipe should put you in 13's alone
Originally Posted by aznprid972
Almost 99%, if not all the people running the drop resistor use a toggle switch for W.O.T. I'm not really familiar, and I don't need to be since I'm running a manual tranny, but basically using a toggle switch recognizes the difference btwn. W.O.T. and anything less than that, and will "shut off" the hard shifts if it detects any kind of throttle pressure besides W.O.T., so it will only be used when racing/d!cking around.
I've got a DR on my auto max and can chirp 1-2 at WOT. Its an easy mod but a tranny cooler is recommended to keep the tranny from melting. If your pushing alot of power through your tranny it will make your shifts much faster and maybe shave a tenth, but it wont shave much off a stock setup.
doctorpullit
12-12-2015 09:39 AM
DC_Juggernaut
09-28-2015 04:07 PM
