EGR Flow malfunction ??????
Old Aug 22, 2004 | 01:01 AM
Reaction021's Avatar
today the engine light was on i check it with a scanner and the code came out to EGR Flow Malfuction anyone know what's this mean any info provided would be greatly appreciate
95 Maxima GXE 5 Speed 140K
Old Aug 22, 2004 | 04:42 AM
deezo's Avatar
I know those things get clogged really bad. You may need to take it apart to really know.
Old Aug 22, 2004 | 09:18 AM
Ceasars Chariot's Avatar
Old Maxima Legend
0302
Diagnostic Trouble code 0302 points to a problem with the Exhaust Gas Recirculation system. The malfunction is detected by the Engine Control Module when no EGR flow is detected under conditions which call for EGR. Possible causes include:
- The electrical harness or connectors (valve circuit open or shorted)
- The EGR valve is stuck closed
- Weak or dead battery
- The EGR passage is clogged
- Faulty EGR temperature sensor circuit
- A leak somewhere in the exhaust system
The EGR Volume Control Valve may be tested with an ohmmeter. Disconnect the electrical connector. Looking at the connector half which is attached to the EGRVCV with the latch at the 12 o'clock position you will see two rows of three terminals. The top row is numbered 1-3, right to left. The bottom row is numbered 4-6, right to left. Measure the resistance between these terminal pairs:
2 1
2 3
5 4
5 6
... all resistance values should be 20.9-23.1 ohms at 68 degrees F.
Reconnect the EGRVCV connector halves. Turn the ignition switch ON OFF repeatedly. Verify that the EGRVCV shaft moves smoothly forward backward according to the ignition switch position.
The Exhaust Gas Temperature Sensor may be tested with an ohmmeter. The specifications are ...
- at 32 degrees F, 0.68-1.11 Megohms
- at 122 degrees F, 0.09-0.12 Megohms
- at 212 degrees F, 0.017-0.024 Megohms
0303
Diagnostic Trouble Code 0303 indicates a problem with the front Oxygen Sensor on the left cylinder bank. The left bank is also called the front bank. It is cylinders 2,4,6. A normal signal sweeps back and forth between 0.2 volts and 0.8 volts. This malfunction was detected when the Engine Control Module received a signal from the sensor which was a constant value of approximately 0.3 volts.
Possible causes include ...
- Harness or connectors (the sensor circuit is open or shorted).
- Defective Oxygen Sensor
Old Aug 22, 2004 | 12:06 PM
can i get an pic of where the EGR is located i'm a noob to this Thanks
Old Aug 22, 2004 | 12:10 PM
DAVE Sz's Avatar
Hooooooonda.....
sig..........................
Old Aug 22, 2004 | 12:14 PM
thanks for the pic
TallTom
57
Oct 14, 2025 05:16 PM
shilov
Feb 19, 2024 09:40 PM
bumpypickle
Sep 19, 2015 01:07 AM
Justin Kroll
Sep 2, 2015 11:06 AM
