sunroof drain leaking into car
I would like to know where the drain tubes come out from the sunroof drains. I tried to clean out the driver's side drain from the top with compressed air, but it still leaks. I'd try from the bottom but I can't find anything on the bottom of the car. Anyone had success fixing this problem? Getting tired of dripping water every time it rains hard. Thanks
The drain hose has probably disconnected or leaks at the connection point on the track assembly. Pull the corner of the headliner down and make sure the drain tube is tightly connected. Keep the track/frame assembly clean and free of debri so the water drains out easily.
there are 4 drains...one in each corner. for the front ones you can remove the kick panels and fish around in there, they should be there somewhere. if not than they come out behind the front fenders and you can try removing the wheel well plastic covers to get to them...crank the compressor up to 120 psi thatll do it. the sunroof can leak from anywhere and come out from the headliner somewhere else so check all the tubes.
carguy96
20
Feb 6, 2021 06:21 AM
Lakersallday24
Jun 16, 2019 01:35 AM
altome15
Aug 10, 2015 07:05 PM
erniel
Aug 8, 2015 09:32 AM
