most common problem with radiator??
Old Aug 22, 2004 | 04:41 PM
maximus_pr's Avatar
i think my radiator is leaking but cant find where because i see spots evrywhere on engine bay i think it may be the radiator cap any advice here
Old Aug 22, 2004 | 04:53 PM
gtr_rider's Avatar
192.168.1.1
You are going to need a radiator very soon, also those spots stain.
Old Aug 22, 2004 | 05:08 PM
maximus_pr's Avatar
already cleaned my engine bay but radiator looks in very good shape i need to know if the thermostat fails and car overheats if it may start leaking through the cap?
Old Aug 22, 2004 | 05:17 PM
gtr_rider's Avatar
192.168.1.1
When this happened to me there was a hairline crack underneathe the filler spout which would spill fluid all over the engine bay leaving spots. If you dont watch the level of fluid in the radiator it may overheat.
Old Aug 22, 2004 | 05:54 PM
michaelnyden's Avatar
where exactly is it leaving spots on a level surface? right in front of the passenger side cv joint (right by the right wheel area)?? then it's a "weep" hole around the water pump... on the block....drove me crazy when I first got my 4th gen...couldn't figure out where it was coming from...it was dripping off of my A/C compressor...so I thought it had something to do with that....but it wasn't....it means your water pump gasket is old and probably messed up...just get some radiator stop leak....fixed it right up and flush all your radiator fluid at the same time...then pour the stop leak in....certain ones are great i hear....don't remember which I used, but it came highly recommended as it was made to simply rebuild/recondition water pump seals rather than clog stuff up...
Old Aug 22, 2004 | 05:55 PM
maximus_pr's Avatar
i found out a have a hairline crack too but 4"-5" left to the filler opening just where theres a rectangular shape molding
i can't see it but i just came from my mom's house and smell like coolant and saw very small coolant came from that spot i dry it with tissue and saw exactly where it was leaking is so small i can't see it
DJLAX152
May 4, 2021 11:46 AM
Excalibur23
Oct 13, 2015 04:33 PM
RWCreative
Sep 21, 2015 11:01 AM
videomano
Sep 8, 2015 03:28 PM
