check engin light on
Old Aug 23, 2004 | 12:36 PM
kabam's Avatar
HI all,
My 96' Maxima Engine light is on and AUTO-ZONE give the code P0704, which is said gear 4th incorrect and the computer said Clutch Switch Malfunction. What does this all mean? Do I need to replace my Clutch Switch or Clutch?
Also, Do I need to replace my timing-belt? I never got it replace before because my friend told me it is a chain-timing-belft so I don't need to replace it. It this correct?
Kabam
Old Aug 23, 2004 | 01:42 PM
DAVE Sz's Avatar
Hooooooonda.....
I already told you in the last thread that a P0704 isn't a valid code on the 96 max according to the FSM. It's either p0740 or p0734.
Old Aug 23, 2004 | 01:51 PM
Kevlo911's Avatar
Kevlo for President
Why don't you check the codes yourself, read the sticky that says "Help my check engine light is on!"
Old Aug 23, 2004 | 04:38 PM
kabam's Avatar
p0734 = 1106
Ok, just went back to auto-zone and got a code p0734, which is (code 1106)Improper Shifting to Fourth Gear (A/T). So, what does this mean and what do I need to do to get that check out?
Thanks,
Kabam
Old Aug 23, 2004 | 06:31 PM
DAVE Sz's Avatar
Hooooooonda.....
Go to the dealer, you obviously won't be able to fix it. That code is mechanical not electrical. Meaning that a solenoid or something might be bad.
Old Jun 7, 2005 | 12:11 PM
Chrismuller's Avatar
P0740
Do you know what I should do for a P0740 error? The description is TCC Circuit Malfunction.
thanks
Chris
Old Jun 7, 2005 | 12:14 PM
96GLEMAX's Avatar
Also, your Maxima has a timing chain, not a belt. The chain is vertually maintenance free as I understand it. Someone correct me if I'm wrong....
Old Jun 7, 2005 | 01:25 PM
Chickan's Avatar
correct it is a chain, and if anything, you'd want to replace the tensioner, but that really isn't nessesary.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
