Fuel filter replacement...
Old Aug 24, 2004 | 07:15 PM
Maxima 504's Avatar
I own a 96' with 119K on it an im not too sure if the fuel filter has ever been changed before.. Since I am coming up on 120K miles I was thinking that it would be a good idea to change the fuel filter because my car feels somewhat sluggish.. I have cleaned out my throttle body, changed spark plugs, and cleaned an re-oiled my K&N filter and intake within the last 10K miles.. Would changing my fuel filter possibly help with the sluggishness I feel? All help & input is appreciated.. Thanks..
Old Aug 24, 2004 | 07:18 PM
chuckie311's Avatar
oh yeah if your fuel filter gets to cloged you car will not be running. i would change it out right away before you have more problems than just your furl filter. i would change it about every 30k
Old Aug 24, 2004 | 07:28 PM
maxedout95's Avatar
i dont' think chaning the fuel filter will help much. If you used 93 or better all the time you should not need it. But its not a difficult job to do so you could try it. see what happens
Old Aug 24, 2004 | 07:40 PM
HybriDSM's Avatar
its part of regular maintenance and needs to be done regardless of wether or nt there is a performance gain.....
Old Aug 24, 2004 | 07:48 PM
chuckie311's Avatar
ever look inside if a old fuel filter. its takes all the grim in your fuel and filters it out.just look at this old fuel filter
http://www.motorvate.ca/mvp.php/505
Old Aug 24, 2004 | 08:46 PM
Maxima 504's Avatar
yeah i always use premium gas (93 octane).. I will go ahead an replace it since it should be changed every 30k miles.. I am long over due for replacing it.. Thanks again for all the input..
Old Aug 24, 2004 | 09:23 PM
mansurxk's Avatar
man you gotta love the false information, theres always solids suspended in anything, no manufacturing procedure is perfect, thats why yu need a fuel filter to prevent sediments from entering your system.
Old Aug 25, 2004 | 01:37 AM
Turk's Avatar
I would get one from the with a magnet built into it, because the rust in the fuel system gets trapped on the magnet. I really didn't feel any improvements but knowing that its replaced gives me a good piece of mind.
Old Aug 25, 2004 | 01:38 AM
Turk's Avatar
Stop hanging out with your Honda friends.
Old Aug 25, 2004 | 05:52 AM
Stephen Max's Avatar
Well, okay. Sounds reasonable, I guess, but any rust particles will be trapped by the filter element. Anything small enough to pass through the filter won't do any harm to the injectors.
Old Aug 25, 2004 | 05:55 AM
mzmtg's Avatar
Minister of Silly Walks
Fuel octane rating has nothing to do with how clean it may or may not be.
Change the filter every 30k, no matter what fuel you use.
Old Aug 25, 2004 | 06:32 AM
sagamax's Avatar
Give me a Bud Light Holmes
i wont hurt to replace it its only $10 and takes 10 mins to do
Old Aug 25, 2004 | 07:28 AM
Tyrexx's Avatar
dont expect hp gain............ If you dont remember changing it then change it now.
Old Aug 25, 2004 | 08:12 AM
Nazca's Avatar
Dont forget to depressurize the fuel system prior to taking out the old one. Just pull the fuel pump fuse, then crank the car until it doesnt fire. This will make replacement a little easier and cleaner (less fuel spilled).
Old Aug 25, 2004 | 08:34 AM
95maxWV's Avatar
i bought a 95 max se with 97k on it.. i had to change everything out that i could so that i knew when it was done.. the fuel filter was so dirty and old lookingi knew it was the original one.. when i took it off the gas that ran out looked like oil... car idled a little smoother but didnt make a big difference. but to think that much dirt was just waiting for that filter to somehow let it through was a bad feeling.. its easy to change.. just do it..
Old Aug 25, 2004 | 09:54 AM
ManualMaxima's Avatar
5th Gen till she dies!
do not expect any gains, but switch to a nissan 300zx tt or n/a filter. it last alittle longer and it sounds cool
Old Aug 25, 2004 | 10:07 AM
mikez's Avatar
Is there a "how-to" for changing the fuel filter? I couldn't find one in the maintenance thread.
Old Aug 25, 2004 | 10:27 AM
Tyrexx's Avatar
it sounds cool like "hey I have a 300zx TWIN TURBO fuel filter"?
I thought about that, then decided to just go with the regular one... Just in case.....
Old Aug 25, 2004 | 10:45 AM
SkoorbMax's Avatar
HERE It took me an hour to do, simply because it's a pain unscrewing it and getting large hands in a tiny area, but it's not a difficult job - just a bit messy and time consuming. Make sure you're in a ventilated area with plenty of paper towel, and maybe even a cup to get some dripping fuel. Don't smoke while doing it
Old Aug 25, 2004 | 12:38 PM
Brudaddy's Avatar
I agree....it is hard to do with large hands.
It is not a hard task though, other than fitting your hands down in there.
Just kind of tedious and time consuming.
Old Aug 25, 2004 | 12:39 PM
|Bijan|'s Avatar
UCF Lexus
It depends on if you have ABS or not..
Old Aug 25, 2004 | 03:18 PM
Maxima 504's Avatar
I know for sure it hasn't been replaced since i've owned the car. I've had my 96 since 2001 and ive put almost 30k on it in that time (over 3 yrs).. I think I might just pick up the one sold at AutoZone for $10..
Old Aug 25, 2004 | 08:23 PM
maxedout95's Avatar
well i didn't get that.
BUt going back to the subject at hand, if you change the fuel filter you will not see a significant performance difference. I didn't say you shouldn't change it but its not critical to do it to often. If you ever saw a fuel pump you would notice that there is a filter on that which catches the bigger particles that are in the fuel. Only smaller particles are caught by the fuel filter.
Which shouldn't clog up the filter very quick. So changing it often in not necessary imop.
thats why if i am not mistaken and please correct me the newer maximas have filters that are permanent in the fuel tank. Let me know if i am incorrect on that.
ALso changing the air filter and oil will make the car alot more responsive.
Check this link out http://www.motorvate.ca/mvp.php/505
Old Aug 25, 2004 | 09:39 PM
Max96LSU's Avatar
go to www.motorvate.ca he has a how-to change the fuel filter. You won't feel any gains from changing it but you may notice your idle may be different rigth after you change it... I just changed mine this weekend along with my oil, brakes and rotors. Not to tough of a job.
Old Aug 26, 2004 | 10:23 AM
mikez's Avatar
If I change the fuel filter should the pcv valve also be changed?
If so is it hard to locate and change?
thanks
Old Aug 26, 2004 | 10:57 AM
twiggy144's Avatar
Inspect the pcv valve : take it off the valve cover, shake it in your hands. if you hear the ball valve inside rattling, it's ok.
Old Aug 31, 2004 | 07:49 PM
98maxima5speed's Avatar
you must not know anythnig about cars if you are not going to chage you fuel filter a fuel filter if cloged car cause major hp losses and if you worked on cars witch you dont you would known it could even create a no start condition
why do i know the you ask lets see i have done 5 years of training it the automotive feild and now work for BMW and if you want to ask anyone just go to any dealership and ask one of there techs that and tell them your point and wach them laugh at you the "fliter" on the fuel pump is a fuel pump screen and only picks up larger objects on the 95-99 maxima the filter does the rest im not sure the injectors may also have a screen to catch even finer cointaminates
in short dont give bad info if you dont know
have a nice day
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
