timing chaine sliped
Old Aug 25, 2004 | 03:41 PM
bigx323's Avatar
my timing chain came off in the engine , what kind of damage am I looking at?
Old Aug 25, 2004 | 03:45 PM
Kevlo911's Avatar
Kevlo for President
How did this happen?
Old Aug 25, 2004 | 04:00 PM
datguyclark's Avatar
yea shiit luck...could be reasonable could be a money pit
Old Aug 25, 2004 | 04:01 PM
f550maranello2's Avatar
oh man how did u manage that? your whole valve train needs to be replaced patna
Old Aug 25, 2004 | 04:04 PM
Kevlo911's Avatar
Kevlo for President
So the chain slipped a tooth?
Might as well buy a new engine. Pretty cheap, www.ebay.com or www.car-part.com
Old Aug 25, 2004 | 04:15 PM
bigx323's Avatar
yea, thats what my mechanic said -"could be reasonable could be a money pit" he's taking the engine apart to see what kind of damage im looking at, but its a f'in sh!tty luck
this happened in the last two months :
new starter, ignition switch, knock sensor, flat tire, rebuild trany. My car spends more time in the shop than i do driving it...
Old Aug 25, 2004 | 04:20 PM
bigx323's Avatar
and i have no idea how it happened, few days after picking up the car after a trany rebuil from a shop, it became a pain in the *** to start it, next day didnt start at all.
Old Aug 25, 2004 | 04:34 PM
Kevlo911's Avatar
Kevlo for President
Usually if hte chain skips a tooth, you would feel ALOT of vibrations everywhere. I have never read about a case where hte chain broke or slipped or skipped a tooth. I do know that hte tensioner goes bad though.
Old Aug 25, 2004 | 04:43 PM
4GenMaxMan's Avatar
It is very uncommon for a timing chain to skip. If the tensioner or guide broke than there could be enough slack to allow it to slip. I think that the maxima has a non interference engine so that the pistons won't slap the valves but im not 100% sure. If it only skipped a tooth and didn't break than there should not be any damage.
If you are going to fix it, than replace the water pump while you are in there since it is driven by the timing chain.
Old Aug 25, 2004 | 04:46 PM
bigx323's Avatar
the tension was ok actually when i drove it but then it wouldnt start at all, the mech. say's the chain came off, but now i need to wait till tommorow, when he takes it apart to see the complete list of the damages.
Old Aug 25, 2004 | 04:47 PM
Ant96GLE's Avatar
Well if the chain came off, kiss your engine goodbye
Old Aug 25, 2004 | 04:49 PM
bigx323's Avatar
uncommon my ars, this kind off stuff always happens to ME
Old Aug 25, 2004 | 04:50 PM
njmodi's Avatar
Do I get a tax break?
The VQ30DE/all VQs for that matter ARE INTERFERENCE engines... so a broken chain will cause valve damage.
I am guessing your tensioner was weak (some 95/96s have this problem from the factory)... and that let the chain slip a tooth... not sure if a slipped tooth will cause enough of a timing mislalignment to bend anything... we'll know soon enough.
Good luck and keep us posted.
Old Aug 25, 2004 | 04:51 PM
4GenMaxMan's Avatar
Pray to the car gods tonight.
Old Aug 25, 2004 | 04:59 PM
Jeff92se's Avatar
I'm needing a caw
IF the problem wasn't the tranny shop's fault. And IF it's indeed a slipped timing chain, by all means just put a good used low miler in. $500 for a motor is unbeatable.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
