0504 code 2 weeks after tranny cooler install
Old Aug 26, 2004 | 05:56 PM
athlon omega's Avatar
I had a Hayden 405 tranny cooler installed 2 weeks ago. Today I got an 0504 code from my ECU. I checked it out and it says: Automatic Transmission Control Unit Signal to ECU. Does anyone have any experience with this code? I'm suspecting it may be from the tranny cooler. I had a mechanic install it by the way. Thanks for your help.
Old Aug 26, 2004 | 06:02 PM
One more thing. I checked out the detailed explanations on the FAQ, and it said a cuase could be a faulty or dischrged battery. Two days ago. I went to crank my car but nothing happened. I opened the hood and saw that the hyperground kit was loose. The negative battery cable was connected on top of the circle plate with connectors. In the end I added a one neative battery terminal head to the side of the battery reading negative and left the hyperground kit connected to the negative battery terminal (the original place where the stock connector was). Could this be the culprit? The factor starts and runs fine now, so I'm thinking maybe the code could have resulted from that incident because there were short zapping noises when I was relocating things there.
Old Aug 26, 2004 | 10:06 PM
zazon's Avatar
have you done the drop resistor mod?
Old Aug 27, 2004 | 09:19 PM
I haven't done the resistor mod. I checked the battery connections. There's nothing worng with the car in regards to electrical or mechanical. I reset the ECU last night. It hasn't come back since. I'm keeping my fingers crossed. I don't want to get that sinking feeling when it suddenly comes on while driving.
SmokinMax02
18
Sep 11, 2015 12:25 AM
seesole
Aug 26, 2015 11:22 AM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
