Low Power Under 3000 RPM
Old Aug 26, 2004 | 07:32 PM
JP11283's Avatar
I have a 96 GXE Maxima with an auto tranny. I recently had to have the relay for the fuel pump replaced because it went bad. Before I could got the car fixed, it sat for about a two months. After fixing it, it does not seem to run as smooth and have as much power under 3000 RPM as is did before the fuel pump relay went out. Once it hits 3000 RPM, it seems to have a lot more power. Could this be caused by fuel gumming up in the injectors while it sat for two months? Should I run some fuel injector cleaner though it? Thanks.
Jason
Old Aug 26, 2004 | 07:37 PM
njmaxseltd's Avatar
Check your ECU for codes and run a bottle of Techron fuel system cleaner in a tank of gas.
Is your car up to date with maintenance? Tune up ect.
Old Aug 26, 2004 | 10:42 PM
f550maranello2's Avatar
its every ones best friend the knock sensor
Old Aug 27, 2004 | 07:39 AM
KCMaxima98's Avatar
I changed my KS and still notice a big gain in power right at 3500 rpm. I don't know if it is normal or not but under 3500 rpm the car drives ok, but at 3500 it takes off. Maybe that is just how the max drives. I really don't know since I have just had this car for a couple of months and I bought it with a bad KS.
Old Aug 28, 2004 | 12:14 PM
BradsMaxima's Avatar
Also check the PCV value and the fuel filter if you dont know about it being done for a while.
Old Aug 28, 2004 | 12:17 PM
ABK's Avatar
ABK
That how maxes drive, especially if you got a y-pipe. I can't spin my tires of the line, but if I'm on some crappy surface I will get wheelhop and sometimes torque steer at 3500 rpms.
shilov
Feb 19, 2024 09:40 PM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
