WTF is wrong with my car?
Old Aug 31, 2004 | 01:44 PM
eckohb's Avatar
i just put on my budget y pipe a few days ago, and the only thing i noticed was that it got louder. I havent felt any gains of power. It's mated to my custom bent 2.5" resonated exhaust, and like i said, the only thing thats different is the exhaust note. I just had the oil changed with Mobil 1, tranny fluid flushed with Amsoil, coolant flushed...the spark plugs are 3000 miles old, and are the NGK Coppers. Any suggestions? I run only premium, and to my knowledge, my knock sensor is fine since i tested it with an ohm meter. all o2 sensors are less than 5000 miles. And my G-Tech 1/4 miles are 16's+ and 0-60 in 8s...im pretty dissapointed. Any thoughts?
Old Aug 31, 2004 | 02:06 PM
1FSTMAX's Avatar
Humm you should clean your throttlebody.. that will fix what's ailing yer max..
Old Aug 31, 2004 | 02:07 PM
Ant96GLE's Avatar
Sounds about normal... you dont really "feel" the surge in power like some people make it out to be. YOu definately feel the pick up at mid/high rpms a little more but thats about it... its not the day and night difference people say they feel.
As far as the g tech... they're not all that accurate... and to be perfectly honest you should expect high 15's to low 16's in the 1/4 mile for our cars.
Old Aug 31, 2004 | 02:09 PM
|Bijan|'s Avatar
UCF Lexus
sounds like the throttle body...
Old Aug 31, 2004 | 02:11 PM
eckohb's Avatar
see, the thing is when i had my 96 GLE, with no y pipe, and just a magnaflow muffler, i g teched at 0-60 in 7.06 and 1/4 in 15.5. Now with moderate mods, my 97 se cant get better than that. but i'll try cleaning out the TB. It was done a month or so ago, but it cant hurt to do it again. I'm going to the track on friday, and i was hoping for moderate 15s, but we'll see
Old Aug 31, 2004 | 02:26 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
1. G-tech sucks. Watch how hard it is to get consistant results by going between different dynos of the same brand (nevermind different branded dynos), then tell me that g-tech is accurate.
2. You don't feel the gains of a y-pipe off the line. You'll feel it when you're cruising at 60 on the highway and suddenly feel the urge to go 100. That's when the y-pipe works it's magic.
3. Are you auto or 5-speed? If you're an auto, let me know if you're tranny starts slipping.
Old Aug 31, 2004 | 02:37 PM
eckohb's Avatar
i'm auto...how do i know when or if my tranny is slipping? i'm seriously considering doing the 5 speed swap this winter, but for the time being, i'll have to live with the automagic tranny. explain what you mean gecko
Old Aug 31, 2004 | 02:43 PM
happyricefob's Avatar
V^___^V
reset ur ECU
Old Aug 31, 2004 | 02:46 PM
ABK's Avatar
ABK
I don't know my car wakes up after 3,500 sometimes get wheelhop (mostly due to ****ty tires) and my knock sensor is messed up. You should be able to feel it. Reset your ECU.
Old Aug 31, 2004 | 03:37 PM
eckohb's Avatar
well, i just cleaned the tb, same as before. next ill trey the ecu...if i can find it
Old Aug 31, 2004 | 03:48 PM
nitromax's Avatar
the ecu is behind the plate next to the GO pedal.
Old Aug 31, 2004 | 04:05 PM
Maximus_95's Avatar
uhmm.....no gains with a ypipe? that's strange. have you checked if you were leaking air in any part of the exhaust? because that happened to me.
Old Aug 31, 2004 | 04:29 PM
eckohb's Avatar
see, thats what i thought too, because my y pipe now makes a pssshhhh sound while at WOT. so i took it to car x and they tightened up all the bolts, and made sure there was no leaks. they even put some crap to fill little tiny gaps between the cat and y pipe. so no leaks. im going to reset the ecu after work and see if that does the trick. hopefully it does, because i feel no difference, if i feel a difference, it feels slower. so we'll see what the ecu brings me
Old Aug 31, 2004 | 05:29 PM
joosdawg's Avatar
well if you dont have the problem fixed by friday ill check it out at the track, my car was bogg city until today, because i cleaned my air filter then after that checked the ecu for codes i got the good ol 0505 which of course is no problems . after i checked for the codes and restet the ecu i took her for a spin and for some reason a ton of low end came back and high end was just as good it was crazy so i really hope it stays running like it was today...then maybe i can beat ya , it should be a real good time
Old Aug 31, 2004 | 05:35 PM
eckohb's Avatar
lol, i wont doubt you beating me, especially if my car stays in this shape. haha, but yeah, should be fun.
Old Aug 31, 2004 | 05:40 PM
joosdawg's Avatar
how are you online i thought you are at work?? you sneaky fruitball, and i say w/e because knowing my luck my car will be a dogg and you will beat me it will be interesting. one awsome thing though it should be low 70's on friday night with a low of 60!! so hopfully we both get runs after t5he sun goes down and things cool off we will get better times ehy?
Old Aug 31, 2004 | 05:46 PM
eckohb's Avatar
lol, im at sears man, and no one comes in to buy electronics past 7, so i get two hours of free time. i just bought a k&n panel filter today, and switched out my old fram. that thing was pretty dirty. so hopefully after the ecu resets, my car will be back to it's old self, and hopefully a little peppier.
Old Aug 31, 2004 | 05:55 PM
joosdawg's Avatar
excuse me mr no intake? why is that? u need an intake to beat me...playin youll prolly beat me off the line then but seriously...u want an intake? i got maf adapter and cone filter for it for sale heck ill even put it on for ya before we run or after 1 run to compare lol, think it over and let me know or else see it friday btw maximumhp and i should be to the front gates around 5:30ish depends on milwaukee traffic we are going during rush hour so idk the exact time but ill talk to you about that later tonight when you get home
Old Aug 31, 2004 | 06:32 PM
Digital's Avatar
VIP
Check exhaust for leaks, probably have bad backpressure. Why would you go with a 3.5 inch tip? That's rice. 2.5 is all you need, and it will be consisent with your piping, which SHOULD give you a better backpressure. Ever think of headers?
Old Aug 31, 2004 | 06:38 PM
Terran's Avatar
There is no such thing as better backpressure...Backpressure is ALWAYS bad.
Old Aug 31, 2004 | 06:49 PM
nostrixoxide's Avatar
Digital,
I've never in almost 20yrs of racing ever heard the term "better back pressure".
Is that some kind of oximoron? It's my understanding that back pressure is always a bad thing no matter what kind of vehicle it is. What is important is the velocity of the exhaust, but deffinitly not back pressure.
Another question I ask is what the hell difference does it make to have a larger diameter exhaust tip then the actual exhaust piping. I've never heard of a exhaust tip making or breaking the performance improvement of a custom exhaust system.
Old Sep 1, 2004 | 02:59 PM
TurboMax67
"There is no such thing as better backpressure...Backpressure is ALWAYS bad."
Um your actually kinda wrong there. Less backpressure is good to a point, if its too low you can kiss your torque goodbye.
Old Sep 1, 2004 | 05:29 PM
Digital's Avatar
VIP
nostrixoxide,
What I'm saying is that if there is any leaks in your exhaust it might not HELP your power. So if there is a leak then I guess you are loosing "velocity" and not backpressure, I may have not been clear, but now I understand. Thanks.
And with the larger diameter exhaust tip I figure it would take away from your velocity since the end is larger and it's not straight thru. I can be mistaken. :shrug:
Old Sep 1, 2004 | 05:36 PM
joosdawg's Avatar
i have a 4.5" tip and im lovin it
Old Sep 1, 2004 | 05:38 PM
Ant96GLE's Avatar
Backpressure is bad, what matters is exhaust velocity and how quickly it can escape
Old Sep 1, 2004 | 05:39 PM
Terran's Avatar
Um, no I'm not. Backpressure is always bad. Exhaust velocity is good (which is why you don't want a 5" exhaust). http://www.magnaflow.com/05news/magazine/05sportc.htm.
Old Sep 1, 2004 | 05:49 PM
mansurxk's Avatar
yoru getting robbed of potential HP if you just have a filter panel, hack that airbox if you havnet done so because thats probably getting rid of 50% of the HP the ypipe promises, the stock intake problaby takes enough for the stock exhaust to output, when you increase the amount you can output, you need to increase the amount of air being taken in
Old Sep 1, 2004 | 05:51 PM
Ant96GLE's Avatar
Technically the best free flowing exhaust you can have is one with smaller tips... for example a friend of mine with a Chevelle put a full 3" exhuast from the headers back with 2.75" tips... the smaller tips make the exhaust leave quicker...
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
laparka66
Aug 6, 2015 09:36 AM
