Changed my Knock Sensor today...
Old Sep 1, 2004 | 03:00 PM
Nismo3112's Avatar
Custom User Title
Wow.... I cannot believe I have been driving around with a bad knock sensor. It's as if my car was breathing through a straw.. I thought my car was fast after the 5spd swap, but after the KS swap.. D@MN the car just wants to gooooo.. Installation wasn't that hard, took about 10 min. Heres a pic of the bad knock sensor: Bad one on the left and New one on the right.
Old Sep 1, 2004 | 03:23 PM
waveridr85's Avatar
did you have a cel or no?
Old Sep 1, 2004 | 03:27 PM
mzmtg's Avatar
Minister of Silly Walks
For the 800th time:
The 0304 code by itself WILL NOT SET OFF THE CEL.
Kevlo911's Avatar
Kevlo for President
He prob had hte ghost code.
Old Sep 1, 2004 | 03:53 PM
waveridr85's Avatar
Forgive my ignorance, but then how do you know your knock sensor is bad if everything else is wroking fine
Old Sep 1, 2004 | 03:55 PM
ABK's Avatar
ABK
I had just the 0304 when it first started, then today 2 month later I find that I have 4 freaken codes, read my post maybe you can help me out. I'm really ****ed and if it was my old car, by dash would be bloody.
Old Sep 1, 2004 | 04:33 PM
Nismo3112's Avatar
Custom User Title
I had the Ghost code.
Old Sep 1, 2004 | 04:37 PM
Ant96GLE's Avatar
You know its bad like I just found out...
Bad gas mileage
Sluggish performance
Check your codes
Old Sep 1, 2004 | 05:02 PM
Nismo3112's Avatar
Custom User Title
And for those of you who were wondering...............
Old Sep 1, 2004 | 05:32 PM
gixxermike's Avatar
What exactly is a ghost code. I think I might have a bad ks but not sure, car seems sluggish. I got a check engine light last night and hooked up the code scanner and saw that I had an ignition code and a ks code. Could the ks code have been stored from previously? is that a ghost code, a code that doesnt trip the check engine light?
Old Sep 1, 2004 | 05:40 PM
Ant96GLE's Avatar
Ghost code means it does not trigger the Check Engine Light... in other words you wont know its bad because the light doesnt come on.
Old Sep 1, 2004 | 07:23 PM
ChristheNite
When you say bad gas mileage and sluggish, what were the numbers you were getting for MPG. My car's kinda feeling sluggish, but it might be because i am boost crazy... Is there any way to test this?
Old Sep 1, 2004 | 07:32 PM
Maxine's Avatar
So how do you check for a ghost code??
Old Sep 1, 2004 | 07:36 PM
Maxtank's Avatar
run your ECU self test
4th Gen FAQ
Old Sep 2, 2004 | 05:59 AM
mikez's Avatar
I changed my KS last night, glad your's went fast, mine took 1.5 hours. First bought a 1/2" instead of 12mm by mistake, then broke the 12mm, then dropped the bolt. Toughest part was getting my hand in to start the bolt again.
Glad I did it myself, I think I could do it 30 mins next time.
Old Sep 2, 2004 | 10:29 AM
ChristheNite
This is starting to get confusion, so you check your ECU even thought this wont throw the CEL it will be in the ECU and throw a code - just not the CEL? Is that right?
Old Sep 2, 2004 | 10:42 AM
naijai's Avatar
did mine in about 30mins hand hurt not cut up just hurt from the squeezin
nbstriker10
Sep 4, 2015 04:26 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
