ECU area - reach tach wire
Old Sep 2, 2004 | 08:40 AM
joew's Avatar
I have unplugged the gray connector on the ECU. How do you pop off the white plastic box? I have been trying for a long time.
Old Sep 2, 2004 | 08:49 AM
NmexMAX's Avatar
dot dot dot ...
What are you trying to do with the tach wire? I found it easier to locate it behind the gauges.
Old Sep 2, 2004 | 08:52 AM
joew's Avatar
it's for remote starter. there are several tech sheets directing toward the ECU tach wire.
Old Sep 2, 2004 | 09:05 AM
NmexMAX's Avatar
dot dot dot ...
The ECU tach wire runs from the Engine to the ECU to the Tach . . . behind the gauges. If you can find it in that bunch, good luck , I found it lonely sitting behind the tach as I stated earlier.
Old Sep 12, 2004 | 09:30 PM
joew's Avatar
i just used the white/green tach wire from the ECU. it does't appear to work. what color wire is the tach wire you used. tach wire may have different color from year to year.
KabirUTA13
19
Oct 17, 2015 02:15 AM
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
