starting problem please help
Old Sep 4, 2004 | 05:58 AM
aRand's Avatar
on my '95 maxima I am having trouble starting during mostly cold but also some warm starts. In order to get it to turn over I have to give it alot of gas. I was wondering if anyone had a similar experience or could share some suggestions. Thanks alot.
-aRand
Old Sep 4, 2004 | 03:05 PM
1996blackmax's Avatar
So when you try to start your engine it does not rotate & does not start unless you give it a lot of gas, or it does rotate/turn over but does not start unless you give it gas?
Old Sep 5, 2004 | 08:20 AM
aRand's Avatar
sorry let me clarify, the engine will turn/rotate but the only way to get it started is to give it alot of gas. And it will stall after starting if I dont give it constant gas for about 30 seconds. After that it runs fine and normal. Thanks.
-aRand
Old Sep 5, 2004 | 08:34 AM
njmaxseltd's Avatar
Clean your throttle body.
Old Sep 5, 2004 | 09:50 AM
a_prince1's Avatar
Fuel delivery issues. Start with fuel pressure then go down the system to the injectors.
Old Sep 5, 2004 | 03:55 PM
I think that these guys gave you good advice. The easiest thing is to clean the throttle body, and it is cool to see how much crap you can actually take off. Motorvate at http://www.motorvate.ca/mvp.php/517 has a good example on how to do this. After you do this and you still have issues, get a Haynes manual it has been pretty helpful for me. It has several possible problems your car may have and the things to check, and how to check them.
Old Sep 5, 2004 | 08:38 PM
f550maranello2's Avatar
a prince1 is the man, check ur fuel pressure regulator especially if black smoke comes out of the exhaust when u start it
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
