Winter Wheels?
Winter tires offer a far superior tread pattern/compound for snow and icy conditions. If you had to switch your tires over on the same rims 2 times a year how much would that cost. Up in Canada to mount tires is apx 15-20 dollars per tire. You do the math. Winter driving is just plain harder on your car. Salt etc chews up the finish and the rims. Also, a narrower tire with a taller profile in the winter is going to give you better gas milage (because you are not pushing so much snow out of the way) and a more compliant ride. Keep your stock rims and put on some good snow tires.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
spencerwh1
06-30-2016 05:44 AM
