Just did POP INTAKE......some questions...PLEASE HELP...
Old Apr 7, 2001 | 07:08 PM
1Phat Max's Avatar
what's up guys, i finally had time to do the pop intake...first impression...when i gunned it i felt like i was driving a mustang..that **** really hauls ***..I bought an adapter from my local shop and a filter from from procarparts.com. My first question is are those filter good if anyone has experience with them? also i was not able to get the bottom piece off of the stock intake from the car since i dint have right tools so i just left it there..is there any cons to this? the filter i got did not fit the adapter on the outside but it fit from the inside. Instead of adapter going inside the filter, filter went inside the adapter cuz the mouth of the filter was small. can i have it like this? i put some tape on it to make sure that no air is passing through between the adapter and filter but not sure if i put enough tape. does it matter if the air goes through between the filter and the adapter, cuz i am sure that there is not enough room for some big thing to go through the middle since the filter fits in the adapter just right. please help me with this....thanx in advance..........
Old Apr 7, 2001 | 08:09 PM
matty's Avatar
where did you get adapter
I was wondering did you buy a cone filter seprate from the adapter and if so where did you get the adapter cause i want to do my own intake but i dont know where to get an adapter for between the cone and that thingy (dont know the name of it :P) AND i dont wanna use tape...thanks
Old Apr 7, 2001 | 08:53 PM
1Phat Max's Avatar
ACTUALLY ONE OF MY FRIENDS BOUGHT IT FROM A LOCAL SHOP HERE IN NYC AND HE SOLD HIS MAX SO HE GAVE IT TO ME TO USE...
Old Apr 7, 2001 | 10:11 PM
MaxedOut's Avatar
so where did u put the air temp sensor?
i have an S&B intake... and i cant put my air temp intake sensor anywhere.. so i left it dangling in the engine... did u do this also? or did u drill a hole into the filter and stick the sensor in there?
Old Apr 7, 2001 | 11:28 PM
Rutnick's Avatar
Re: so where did u put the air temp sensor?
Just look at my attachment. Zipties are wonderful things.
Old Apr 8, 2001 | 11:22 AM
MaxedOut's Avatar
hmmm
i cant really see it that well..... but i know other people like drill a hole and stick the sensor in somewhere... but i dont know where... can u tell me where u put the senor? cuz i cant see it real well.....
Old Apr 8, 2001 | 12:50 PM
clee130's Avatar
For the JWT pop intake, you don't have to drill a hole. Why make life harder for yourself?
Just take the filter apart and slide the sensor inside and then tighten the filter back up.
Old Apr 8, 2001 | 01:05 PM
Rutnick's Avatar
Re: hmmm
Did you follow the red arrow? That is where I put it.
Old Apr 8, 2001 | 01:06 PM
Rutnick's Avatar
That would work but the sensor would just rattle around inside the popcharger. I took a picture and showed him where I zip tied it.
Old Apr 8, 2001 | 01:11 PM
Rutnick's Avatar
Old Apr 8, 2001 | 01:34 PM
clee130's Avatar
Not if you slide only a little bit in. Just enough so that the sensor and a little bit of wire would be inside and it wouldn't rattle.
Mine doesn't rattle. And besides... with all the noise (engine, pop intake, radio) you wouldn't hear the rattling anyways.
Old Apr 8, 2001 | 02:42 PM
Rutnick's Avatar
I see what you mean but the sensor looks kinda delicate. I know it has a protector around it but I just didn't like the idea of it rattling around inside the popcharger. I don't know if my zip tie idea is any better though.
Old Apr 9, 2001 | 01:43 AM
Maxima48177's Avatar
For those who are looking for an adapter to connect a cone air intake, you can find it on ebay. I bought mine from ebay and works perfectly. The filter I got is the twister model made by Autotechnics. Everything fits perfectly besides the fact that there is nothing holding the filter up, so it just kinda rests against the metal of the car right on top of the front wheel. Does anyone have an idea to fix this? For the sensor, I just ziptied it near the filter.
Old Apr 9, 2001 | 11:41 AM
Nismo's Avatar
What I used to rest the filter onis the foam gasket stuff that comes with the K&N filter panel . I stuck some under the filter so it cushions it against the metal. works perfect.
Old Apr 9, 2001 | 01:45 PM
clee130's Avatar
I don't know where you guys bought the pop filter from, but I bought mine from Cattman and it came with a bracket to hold the filter up.
Mahmuth
Aug 16, 2024 08:23 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
jsmith24
Feb 1, 2016 12:35 AM
Excalibur23
Oct 13, 2015 04:33 PM
