Re-Setting Spedometer, and Best Wheel Size
Old Apr 8, 2001 | 01:06 AM
SB97MAX's Avatar
Ive heard a lot of people say that if you get new rims and tires that you might have to get your spedometer reset so it is correct. How can you do this? Or how much does it cost on the average to get it done? Also what is the best size wheel to get? Do the 17's rub on the fender at all? My buddy had them a long time ago and said that his did rub a little. I wouldnt ever go any bigger than 17's anyway but was just curious on what a good size for the wheels and tires to be. Thanks
Old Apr 8, 2001 | 08:46 AM
Micah95GLE's Avatar
You don't have to adjust the speedometer if you keep the stock diameter. If you want 17s, the ideal size is 17x8 (35-40mm offset) and 235/45ZR/17. That doesn't even come close to rubbing, even with a lowered suspension
Old Apr 8, 2001 | 10:11 AM
NISMO808's Avatar
so how do u reset the speedo if you got 18's.
Old Apr 8, 2001 | 11:23 AM
buss95max's Avatar
Rims: 16X6.5 Tires: 215-55/16 (225-50/16 will fit)
Rims: 17X7 Tires: 215-50/17 (225-45/17 will fit)
Rims: 17X7.5 Tires: 235-45/17
Rims: 17X8 Tires: 235-45/17
Rims: 18X8 Tires: 235-40/18
str8 from the megamax A.E site....
Old Apr 8, 2001 | 01:02 PM
clee130's Avatar
Try this site...
http://www.miata.net/garage/tirecalc.html
You can calculate how your speedo will be affected with different size wheels and tires.
Old Apr 8, 2001 | 01:51 PM
Micah95GLE's Avatar
You don't adjust the speedometer for 18s or 19s, either, as long as you get the correct-sized tires. It's all about the outer diameter of the tire.
RinconI30
Nov 10, 2015 10:55 PM
meccanj98
Sep 16, 2015 07:23 AM
kadespraggins
Sep 14, 2015 12:04 AM
minsbang
Sep 11, 2015 08:48 PM
dcam0326
Sep 8, 2015 11:02 PM
