Help Sunroof Leak?
Old Sep 9, 2004 | 04:32 PM
komodo693's Avatar
Help Sunroof Leak?
I think my sunroof is leaking but am not sure. In NYC over the last 2 days a couple of really heavy downpours (roads flooding). Water started dripping from the sunroof switch and nowhere else. My max has the sunroof spoiler but I am stumped (car is smelling a little funny also)
Help
Old Sep 9, 2004 | 04:47 PM
99se5spd's Avatar
check your drain tubes , they are clogged. open the roof and in the front 2 corners there are small holes, using an air compressor blow those guys out with at least 80psi. if you dont have access to a compressor, remove the kick panels and they should be in there somewhere, pull them out and clean em out. for the rear ones pull the trim in the trunk on the sides away and fish around until you find the tubes, pull em out and clean. your all set to go! hope this helps
Old Sep 9, 2004 | 06:49 PM
trubd's Avatar
can you give more detailed directions please, my sunroof was also leaking.
Old Sep 9, 2004 | 07:18 PM
komodo693's Avatar
Thank you very much. I have a project to do this weekend! I will post back after I have cleaned the drains. (I go to a car wash to confirm!)
Old Sep 9, 2004 | 09:17 PM
99se5spd's Avatar
trubd: what more info do you need?
komodo: you can just use a garden hose, there is actually quite a bit of water that is let into sunroofs, new or old, fyi.
aw11power
Oct 10, 2021 04:57 AM
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
