exaust stinks
Old Sep 9, 2004 | 06:32 PM
S103100F's Avatar
exaust stinks
what can be a problem? after driving my exaust stinks like bad egs
Old Sep 9, 2004 | 06:41 PM
Terran's Avatar
Bad catalytic converter
Old Sep 10, 2004 | 05:58 AM
S103100F's Avatar
but i heard they newer go bad
Old Sep 10, 2004 | 06:09 AM
PAREDLINE's Avatar
Try a higher octane fuel. If you use regular this happens more. Regular fuel + "performance" driving = rotten egg smell (most of the time)
Old Sep 10, 2004 | 06:11 AM
mzmtg's Avatar
Minister of Silly Walks
That is so, so wrong.
The rotten egg smell is usually indicative of a failing catalytic converter. They can, and do, go bad/wear out.
Old Sep 10, 2004 | 06:33 AM
PAREDLINE's Avatar
Hmm. I'm not going to get into an argument but the rotten egg smell is caused by fuel that does not ignite properly and/or has a higher sulfur content. It causes heat in the exhaust to build up and the element in the catalytic converter begins to get extremely hot and give off that stink.
The cat may be failing even though this would cause at least one sensor to trip and the car would fail inspection. It's a 96 this guy is talking about so it MAY be the cat itself. But the rotten egg smell is caused by heat and sulfur. The higher octane fuels ignite at a lower temperature (lower exhaust temperature) and have less sulfur.
You know.. before you tell someone to replace a cat... why not just do something simple and change fuel brands/grades? This guy relies on you for good information.
Thats like you going to the doctor because you have a headache and he says you probably have a brain tumor.
Old Sep 10, 2004 | 06:35 AM
mzmtg's Avatar
http://www.eng-tips.com/viewthread.cfm?qid=96697
Old Sep 10, 2004 | 08:06 AM
S103100F's Avatar
i have this car for about 1 year and always use 93 gas i did change every thing after converter so it must be converter also my front 02sensor is bad can that cause the smell?
Old Sep 10, 2004 | 08:11 AM
mzmtg's Avatar
The front O2 sensor being bad can cause the engine to run too lean or too rich. Either of those might overheat the cat, releasing the stink egg smell.
Old Sep 10, 2004 | 10:08 AM
S103100F's Avatar
so what should i change first 02sensor or converter?
Old Sep 10, 2004 | 10:11 AM
optimus310's Avatar
What he said ^^
Old Sep 10, 2004 | 10:23 AM
Tyrexx's Avatar
straight pipe time.
Old Sep 10, 2004 | 11:24 AM
S103100F's Avatar
what do you mean straight pipe time?
Old Sep 10, 2004 | 11:38 AM
Terran's Avatar
Get rid of the cat and replace it with a "straight pipe" (just a pipe the same length as the cat, but just like any other part of the exhaust). If your state has emissions testing this woud make you not pass...It will be cheaper though, and might give a few HP.
Old Sep 10, 2004 | 12:03 PM
Keyser Skoze's Avatar
cheaper yes but like 2 more hp from what i understand
K & N
May 31, 2001 09:34 AM
MAX95GLE
Nov 30, 2000 12:09 AM
96BLUMAX
Nov 17, 2000 02:35 PM
ryan
Nov 7, 2000 09:39 PM
