Dead silence when trying to start then BOOM
Old Sep 9, 2004 | 06:56 PM
bladeboy66's Avatar
I have a 1997 Max- here is the problem. sometime when you put the key in the ignition and turn it will start right up.
Other times you put the key in and turn the light comes on but nothing happens and if you flip the key a few times or if you turn the key quickly with a bit of stength she will also start right up.
Any thoughts?
Thanks.
-Jon
Old Sep 9, 2004 | 07:34 PM
nostrixoxide's Avatar
Sounds like your ignition switch is going bad. Do you have a heavy key chain? Alot of weight hanging there can damage the ignition switch.
Old Sep 9, 2004 | 07:43 PM
97WhtSE's Avatar
mine was the exact same way but i just had a cable loose so i just tightened that up and it works like new again!
Old Sep 9, 2004 | 08:45 PM
Nismo3112's Avatar
Custom User Title
I replaced my ignition switch not too long ago. The difference between a good and bad one is night and day. It takes about 15 minutes to replace and costs about $38.
Old Sep 9, 2004 | 09:01 PM
ionpcs's Avatar
have the same problem in mine. right now i'm far too poor to worry about such things. just turn the key really quick like i'm trying to sneak up on the ignition switch and it usually works. when i got it i had to sit in the car for 10 minutes trying to get it to turn on only to have it randomly work sometime.
shilov
Feb 19, 2024 09:40 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
