Where do you go through the firewall on a 4th gen
Old Sep 12, 2004 | 04:25 PM
Nealoc187's Avatar
SLOW
Stupid noob question. I'm tired of running my MEVI wires through my doorjam and I want to run them through a grommet in the firewall. I haven't looked at it yet today but in the past I have never found an acceptable place. Anyone know?
Old Sep 12, 2004 | 04:37 PM
maxima98vspec's Avatar
there isn't a path unless u make one. but i just went through the round hole in the corner by the master cylinder that has a harness going through and then it goes into the fender well and then it goes in the passanger compartment
Old Sep 12, 2004 | 04:41 PM
mzmtg's Avatar
Minister of Silly Walks
The answer lies in the Modification FAQ.
EDIT: oops, regular FAQ
http://forums.maxima.org/showpost.ph...2&postcount=45
Old Sep 12, 2004 | 05:43 PM
chuckie311's Avatar
i ran mine thought the driver side hood latch grommet
Old Sep 12, 2004 | 05:53 PM
gtr_rider's Avatar
192.168.1.1
do you have a picture of that, I was trying to find that while installing my sub power wire, but I gave up..
Old Sep 12, 2004 | 06:02 PM
1996blackmax's Avatar
I actually drilled a hole through the firewall. If you look by where your left foot rests in the car (I have an auto) go up from there. You will see a cutout on the rubber part, pull the cutout and you will see metal. This is where I went through to get my power cables to the trunk. There is a matching cutout on the engine bay side, it is that gray material. Do this and get a rubber grommet and you're set.
Old Sep 12, 2004 | 07:15 PM
RA030726's Avatar
I'm nutty for Nissans
there is a grommet under the cruise control ball thingie (sorry for not knowing the real name). its near a white plastic clip that holds the metal hard line that comes off the IM, and goes over tward the brake booster.
Old Sep 12, 2004 | 08:19 PM
Nealoc187's Avatar
SLOW
I got
Old Sep 12, 2004 | 09:07 PM
chuckie311's Avatar
you ahve to Remove the wheel well liner of the left-front wheel and you will see it.. on the inside you have to pull the carpet down to find it. just trace out where the hood latch goes though and you have it..
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
ef9
Sep 29, 2015 11:29 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
