Hole in my muffler? !@$^%*
Old Sep 12, 2004 | 05:31 PM
mendon99's Avatar
tastey wheat
Hey guys, just recently there has been this sound coming from my muffler (at least it sounds like its from my muffler), sounds like there is a hole in it, but it stops after 2-grand rpm...doesn't make any sense! if there was a hole wouldn't the sound be there all the time?? i looked under my car and the muffler looks fine, no holes..im stumped. any thoughts?? thanks in advance -
Old Sep 12, 2004 | 05:36 PM
drunkenmunky23's Avatar
jack up the car and start the car, and feel around the exhaust piping for a leak...just amke sure its a cold start so the exhaust is cool and u can check for a hole b4 it gets too hot
Old Sep 12, 2004 | 06:01 PM
d280c's Avatar
You don't hear the noise at high speeds because of at least 2 factors:
1. Increased road noise
2. Less turbulent air flow thru the exhaust, since more exhaust gas is being pushed out, they then to go thru the "smoothest path" which is less turbulent hence less noise.
In time the hole will get bigger and the noise will get louder. You should check the point behind the muffler where the exhaust pipe sticks out - i.e. towards the b-pipe. At the weld between the muffler body and the pipe itself is a very common place to rust and develop holes. I just changed mine
Old Sep 13, 2004 | 10:58 AM
mendon99's Avatar
tastey wheat
Ah. thanks.. if its either of those, then it would be # 2... thanks man ill take a look again
Turbonut
46
Oct 21, 2015 08:28 PM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
max ride 41
Sep 17, 2015 06:17 PM
TheMafia
Sep 4, 2015 08:26 AM
