Vibration when breaking
Old Sep 13, 2004 | 06:18 PM
Bernie's Avatar
I have had a situation for a few months now where breaking causes a pulsation of the break pedal, but no shaking of the steering wheel. I have attributed this to warpage of the rear rotors, and have purchased replacements, though have not installed them yet. Today however I experienced a new problem. While breaking at high speed (approx 130KM/hr) I experienced significant vibration accompanied with shaking of the steering-wheel This was new. But get this, it did not happen every time! Sometimes I thought it was bad when I was in a turn, othertimes it just did not happen. Any thoughts?
Old Sep 13, 2004 | 08:01 PM
f550maranello2's Avatar
dude it ur rotors just replace them
Old Sep 13, 2004 | 08:06 PM
mzmtg's Avatar
Minister of Silly Walks
B-R-A-K-E
Old Sep 14, 2004 | 09:24 AM
Bernie's Avatar
I appreciate your advice, but why the problem only some of the time?
Bernie
Old Sep 14, 2004 | 09:33 AM
dgeesaman's Avatar
Maintenance Monster
Mebbe something is sticking or the pads aren't moving evenly. Have someone qualified look at it:
- sticking caliper guide pins
- sticking caliper piston
- damaged pad shims, hardware
- warped rotors
Dave
Old Sep 14, 2004 | 09:55 AM
DragonMaxima's Avatar
Do you have ABS?
Old Sep 14, 2004 | 11:39 AM
96pearlmax's Avatar
maybe alignment or balance is off
Old Sep 14, 2004 | 11:56 AM
XeroX's Avatar
Hella internets
Ok here, if you know how to change your pads...you can do this yourself..
Check out your pads. Look for warpage in the rotors (front) and replace if you can see some.. if not, leave em on untill you KNOW they are warped. Untill then just do the rear rotors. While your at the front , re grease the guide pins (and clean them thouroghly with brake cleaner, clean the whole brake system off completely and reinstall.
Make sure that you dont oil them up too much as they will "hydrolock" and get stuck in one possition, wich i presume is your problem now.
If you do not know how to do all of this, this is a good write-up on how to do it(http://www.motorvate.ca/mvp.php/300). (this is what i learned on) this is only for the fronts tho, and the rears are SLIGHTLY different, like instead of pushing the caliper in with a C-clamp, you have to screw it in, literally..wich is a BIOTCH, unless you have the tool..
Hope this helped!
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Need help
23
Oct 2, 2015 08:56 AM
06maxima55
Sep 28, 2015 04:29 PM
