Knock Sensor Assistance Needed
Old Sep 14, 2004 | 02:57 PM
Kraze D's Avatar
I've replaced my rotors/pads, spark plugs, fuel filter and did an intake mod. And now i'm onto replacing the ks like many others have. When I read the how-to's it seemed like it's pretty easy, however I just can't get the bolt loose! It won't move a bit no matter how hard I turn. Plus it's really tight in there and only my left hand could go in and barely fits in. I got cut up a few times and still the bolt won't move at all.
Now as you may know, I do not want to remove the entire intake manifold as it requires hours of work and is pretty complicated. So here I am, seeking advise/suggestion on how to get the bolt to come off. Thanks all.
Old Sep 14, 2004 | 03:01 PM
Kevlo911's Avatar
Kevlo for President
Try an open end wrench. It is only TQ'ed to like 15, it should not be hard.
Old Sep 14, 2004 | 03:13 PM
Chunger's Avatar
My other car is a Hybrid
2 long extentions with a "u-joint" will do it. I just did it this weekend...
I suggest using a 6 point socket (not the 12) so as to minimize the possibility of stripping the head of the bolt.
Old Sep 14, 2004 | 03:14 PM
BlackCat's Avatar
RIP '98 Maxima SE
Its not hard to loosen the bolt.
http://forums.maxima.org/showthread.php?t=333236
Old Sep 14, 2004 | 03:31 PM
nismomax98's Avatar
ks
when i did mine i sprayed some wd-40 to get it loose it worked nice
Old Sep 14, 2004 | 04:16 PM
goodhead's Avatar
to u joint, go get one in every size it will save you alot of time on projects
Old Sep 14, 2004 | 06:15 PM
gixxermike's Avatar
squeeze your left hand in there along with a 10 or 12 mm wrench (i cant remember which one). put some petroleum jelly on your hand, trust me it helps a ton. Put the box end of the wrench on the bolt head and use the leverage of your hand against the intake to break it loose. It hurts but just suck it up and it will break free. The harder you leverage the sooner it will break free and the easier it is on your hand. Just be tough about it. I tried the u joint first to no success and then found it very easy to use the box end wrench.
Old Sep 14, 2004 | 08:12 PM
maximalnemisis's Avatar
http://www.skippynet.com/maxima/knocksensor.htm best site I did mine in about 15 min. it was so east and I was a bit nervous about it because of all the people on here that have had problrms follow the instructions too the and it will work
Old Sep 14, 2004 | 08:42 PM
ChrisA's Avatar
i had trouble with mine too. but it finally came loose with some combination of extensions and possibly even a pipe for leverage.
i do remember it got to the point where i was pushing so hard i knew i would either strip the bolt, break the tools, or get it loose and it finally gave.
Old Sep 14, 2004 | 10:15 PM
gixxermike's Avatar
Just get tough on it!!!!
Old Sep 14, 2004 | 10:29 PM
MrDicks95SE's Avatar
Offset Is Everything.
hah i can get my whole hand and arm in there easily, got scratched and burned replacing my friends ks. yes thank god for the U-joint. it helps a lot. dont lose any pieces to the dark abyss below.
Old Sep 15, 2004 | 11:22 AM
Kraze D's Avatar
Actually I've been really tough on it every time I try. And I've tried u-joint, open-end wrench and rachet, nothing worked.
But I'm gonna try it again tonight when the engine is still warm, maybe that'll help since the bolt would be "expanded" by the heat. Thanx guys.
Old Sep 15, 2004 | 11:25 AM
Kevlo911's Avatar
Kevlo for President
You will get burned.
Old Sep 15, 2004 | 12:30 PM
Chunger's Avatar
Not if you wait until the engine cools off... hehe
You really don't need the engine hot... i don't think it would help.
Old Sep 15, 2004 | 05:03 PM
JohnPry's Avatar
Just replaced mine last night. It was very difficult to get off. I tried the 1/4 socket wrench as explained in the "how to's" and it would not move. I then connected the toque wrench to the end of the 1/4 extesion and the long handle gave me the leverage I needed.
Old Sep 15, 2004 | 06:53 PM
all you need is leverage and torque. thats all there is to it.
Old Sep 16, 2004 | 08:55 AM
Chunger's Avatar
I don't think a 1/4" drive will provide enough torque... I used a 3/8" (standard size) and it still required a lot of effort.
Old Sep 16, 2004 | 09:53 AM
gixxermike's Avatar
The easiest way is with a box end wrench. Just lube your left hand up and squeeze it and the wrench down in the hole and then get the box end on the bolt and break it loose.
kjlouis
Nov 24, 2018 06:09 AM
smplyamzng
Dec 13, 2015 01:19 PM
maxinout93
Oct 27, 2015 01:29 PM
maxinout93
Aug 20, 2015 02:17 AM
TonyJr
Aug 20, 2015 12:14 AM
