Help removing Stripe
Old Sep 15, 2004 | 05:35 PM
gtmuggs's Avatar
Can anyone tell me the easiest way or best way to remove the stripe from my car
Old Sep 15, 2004 | 05:51 PM
Terran's Avatar
Pin stripes you mean? Mine just peeled off. If not, try a heatgun/hair dryer. Mother's prewax cleaner and some elbow grease works well to take off the residue left from the glue.
Old Sep 15, 2004 | 06:33 PM
gtmuggs's Avatar
yeah the pin stripes is what i want to remove
Old Sep 15, 2004 | 06:44 PM
southeast_first's Avatar
leave one side parked facing the sun on a hot day, for about an hour. the pin stripe should peel off fairly easily, then do the same for the other side. if you get the stripe TOO hot, it will actually leave more adhesive on the car. just get some goo gone or similar stuff to remove the glue that's left over.
Old Sep 15, 2004 | 06:50 PM
mansurxk's Avatar
hair dryer, and plastic putty knife might help, peel away, use the hairdryer in the next spot you intend to peel, itll start coming off little by little if you do it correctly. eventaully if the adhesive gets gooey you can pull most of it off in one stroke
Old Sep 15, 2004 | 08:59 PM
GodFather's Avatar
Made in Taiwan
dude, face the stripe to the sun for about an hour, then dip some acetone to the paper towel. rub it against the stripe and use finger nail carefully scrape it off. you won't hurt the paint yet, after you get them off. please go wax your spots where you remove the stripes. I did mine, and i used maguire yellow wax three times on the spots. my car turned out fine. no paint off.
Old Sep 16, 2004 | 05:28 AM
MaxedOutOfCash's Avatar
Pizda Boy
wow you guys make it hard on yourselves...
it took me all of 3 minutes to take my stripes off...
Go to Home Depot or Sears, whatever & buy a "stripe off" wheel....
So you'll say that you don't have a compressor.....
put it on a regular drill (yes one of these)
and get to work........
sure it's cheaper if you let it sit in the sun & use your fingernail but who wants to do that?.................
Good Luck.
EDIT: and of course wax it after you finish
Old Sep 16, 2004 | 07:33 AM
Terran's Avatar
Yeah I've used those on really tough ones...but I didn't want to try to describe it. Mine literally just peeled right off without even being heated (in the sun or otherwise). It really just depends on how well they're on there.
Old Sep 16, 2004 | 11:24 AM
Max Mutes's Avatar
MaxedOut you're the f*ckin MAN!! I never seen or heard of that before and my pinstripes are a B*tch!! Only the rear fenders pulled off nicely. Wow, I'm goin to get one right now. Hopefully it ain't over $50. LoL.
Old Sep 16, 2004 | 11:52 AM
Pizda Boy
haha....good luck...it's not that expensive.
Old Sep 16, 2004 | 11:53 AM
Pizda Boy
oh yeah.... just be careful not to press to hard so you don't burn the paint... do it carefully if you've never done this before...
EDIT: and don't put it on full speed or anything....
Old Sep 16, 2004 | 12:56 PM
|Bijan|'s Avatar
UCF Lexus
Rub mayonasie all over the stripes and leave it out in the sun all day.....they'll peel off by the heat
Old Sep 16, 2004 | 01:01 PM
Ralph Wigum's Avatar
haha thats a new one
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
