Anyone know the other site for checking ECU codes?
Old Sep 15, 2004 | 07:15 PM
maximaseefu's Avatar
The one from Vbxmaxima is not working.
TIA
Old Sep 15, 2004 | 07:26 PM
Terran's Avatar
That's the only one. What code are you getting? Somebody might be able to tell you.
Old Sep 15, 2004 | 08:31 PM
03 04 and 03 06
Old Sep 15, 2004 | 08:32 PM
crap, i have a sinking feeling my cylinders 4 and 6 are misfiring.....I think I have had these codes before now that I am posting them. if so, anyone have the diagram for which cylinder is which?
Old Sep 15, 2004 | 09:04 PM
Nealoc187's Avatar
SLOW
0304 is knock sensor. 0306 i don't know but if you or someone else has access to search could search for it real quickly.
Old Sep 15, 2004 | 09:05 PM
Nealoc187's Avatar
SLOW
btw the misfire codes are 0603 through 0608 so it's not a misfire.
Old Sep 15, 2004 | 09:21 PM
thanks nealoc. It was close though because I have replaced the coils before and the codes looked familiar. anyone can give me code for 0306 that has search?
Old Sep 15, 2004 | 09:22 PM
never mind guys but thanks....it is
0306 EGRC BPT valve
what the hell is that?
Old Sep 15, 2004 | 09:26 PM
ok, found out through google it is egr valve. where is this located and what does it look like???
Old Sep 15, 2004 | 11:06 PM
Nealoc187's Avatar
SLOW
egr valve is on the back of the intake manifold its what causes most of the mevi guys a problem getting to, it's not fun to work with. its held onto the back of the intake manifold by 2 bolts, 14mm if i recall, and is on the end of a tube that goes down to the exhaust manifold. egr stands for exhaust gas recirculation. it is probably encrusted with oily carbon gunk buildup.
Old Sep 16, 2004 | 03:46 PM
thanks for all the help nealoc. would this valve being clogged up cause the idle to fluctuate and loss of power to the point of the car almost dying?
Old Sep 17, 2004 | 08:17 AM
maximaman10's Avatar
0304 is #4 cylinder misfire, 0306 is # 6 cylinder misfire
Old Sep 17, 2004 | 10:59 AM
blacck_dragon's Avatar
Check out MOTORVATE
http://www.motorvate.ca/mvp.php/523
Old Sep 17, 2004 | 11:04 AM
Terran's Avatar
I am absolutely sure that 0304 is the KS, so no it is not a #4 cylinder misfire.
Old Sep 17, 2004 | 07:00 PM
thanks a lot guys, gonna attempt to clean my egr valve tomorrow. any tips??
sctludwig
Sep 1, 2022 01:32 PM
ballerchris510
Sep 10, 2015 09:35 PM
Maxima30
Sep 7, 2015 06:13 PM
mix master
Sep 4, 2015 05:50 PM
