ecu codes 155 & 325...related?
i have two - 155 ("upstream oxygen sensor heater or circuit fault.") and 325 - knock sensor... I was reading the "Ecu Codes Defined Again" and am wondering whether it is possible that heater problem (a no-fire symptom) causes the engine knocking (knock sensor code)? i.e. replacing 155 will fix the heater problem and eliminate engine knocking (325)???
thanks
thanks
not the most mechanically inclined but with a bad o2 it could be causing more knock. Try replacing you o2 and reset the ecu and see if the KS code comes back.
Maybe also get a volt meter and check your KS, see if its truely bad.
just to get the ball rolling . . .
Kyle Lee Cleveland
09-28-2015 09:01 PM
