Replacin o2 sensor
Replacin o2 sensor
Today, I called Pep Boys and I asked them how much was an o2 sensor for my car.. They asked me what make it was and also is my o2 sensor behind or in front of my cat converter or behind?? I said I dont know, but he told me when I do, its $80 for the one in front and $110 for the one behind.. Which 1 do i get??
0503
Diagnostic Trouble Code 0503 indicates a problem with the front Oxygen Sensor on the right cylinder bank. The right bank is also called the rear bank. It is cylinders 1,3,5. A normal signal sweeps back and forth between 0.2 volts and 0.8 volts. This malfunction was detected when the Engine Control Module received a signal from the sensor which was a constant value of approximately 0.3 volts.
Possible causes include ...
- Harness or connectors (the sensor circuit is open or shorted).
- Defective Oxygen Sensor
Originally Posted by S103100F
0503
Save money and do it yourself. The O2 for the right bank (near fire wall) is very easy to change. Need to put car on jack stands, however. You can borrow an O2 socket from AutoZone. I got mine for $5 from Habor Freight Tools.
I'd like to do everything DIY style too. The only problem is that the parking lot at the apt complex I live in has an incline and no level surfaces. If i were to jack the car up, should I jack the front end of the car going against the decline or with the decline? I'd imagine against the decline, but just making sure. I only ask this because there's absolutely no flat surface I can use, or it's considered loitering (empty parking lot).
I had the exact same problem, bought mine at OxygenSensors.com for $62.99 shipped... Arrived in a couple of days and everything's cool
Sorry to butt in on the thread.. I'm throwing the code 0702. On oxygensensors.com, is that the left front or the right front? I know the code read right bank, but is that from the driver seats point of view. or when you look at it as you stand in front of the car? which one should I order? I'm confused because they're different part numbers.
hmm the code refers to the right, or rear, bank. To me, it seems it's the right side, but then again, I really just want to make sure so I don't go through the hassle of returning/exchanging/etc etc. arg
I'm in a similar situation. Sunday afternoon I started my car up after it was sitting cool all night. As soon as I turned the car on the CEL was on and it stayed on.
This morning I took it to the dealer I got it from and one of the repair men scanned it for me. It threw a code for a o2 sensor as I suspected, because since the light went on my mpg got worse. So he assured me it's a common problem with Nissans and reset the ECU and said that if it happens again to change the o2 sensor, if not then it was a false alarm.
So, I drove to work and it was fine...
My question: Is a false-alarm CEL triggered by an o2 sensor common? Also, the code said that the B2S1 o2 sensor threw the code. Does anyone know exactly which o2 sensor that is? Just curious in case the CEL goes on again and it needs to be changed
One more thing, I've heard that if you get gas with your car on that it can cause extra air to go into your gas tank and throw off an o2 sensor. Is this just a silly myth or does it have some validity to it? I've only had my '95 for 3 months now, but prior to it I had an '89 Max which I've had since I started driving (for 5 years) and haven't had a single o2 sensor problem and I've always filled my tank with the car on, so I'm thinking either that's a myth or the later generation Maximas have more sensitive sensors.
Thanks guys
Thanks guys
Seems like the 0702 is kinda general as far as the 3 way catalyst system. Only other thing I can think to do is change the rear O2 also. Can this be caused by something else along the lines of A/F mixture? and just in the rear bank?
Bugging the **** out of me!
let me know how it works out when you pin point the solution.
0702
Diagnostic Trouble Code 0702 points to a problem with the three-way Catalytic Converter.
The Cat is one of the principal components of the emissions control system. The Engine Control Module monitors the signals from the two front Oxygen Sensors and the one rear Oxygen Sensor. The signal frequency of each sensor indicates something about the condition of that sensor. A comparison of the frequency of the front sensors with the rear sensor indicates something about the condition of the Cat.
This malfunction was detected when the ratio of the signal frequency from the right bank front Oxygen Sensor to the signal frequency of the rear Oxygen Sensor exceeded a critical threshold value. This indicates that the Cat does not have enough oxygen storage capacity. The right cylinder bank is also called the rear bank. It is cylinders 1,3,5. Possible causes of this DTC include ...
- Three-way catalyst
- Exhaust tube
- Intake air leaks
- Fuel injectors
- Spark plugs
- Ignition timing
0702
- Exhaust tube
- Intake air leaks
- Fuel injectors
- Spark plugs
- Ignition timing
if youre mileage sucks or you are getting an engine light code, change them, oem says to every 60000mi, but you can also torch them to clean them out and also use a little brake cleaner and then reinstall, check ebay as borg warner am parts are usually the cheapest, i.e. 30$US plus ship. reset your engine ecu light manually after pulling the codes the same way. dealers charge too much for their scope...
o2 aftermarket
2 Sensors/97SE
dealer tells me the left or rad side 02 is different from the right or firewall side one. looks to me like the oem difference is only the length of the cable but dealer says whole thing is different. does anyone know for sure if you can install a bw sensor in both applications even with the extra length of cable?
(i know the cat area sensor is totally different, but, thats not the issue)
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
