oil pressure sending unit leaking...need help
Old Sep 21, 2004 | 07:24 AM
erty67's Avatar
Decal Specialist
Yesterday, i went to get my oil changed. When they were done, the guy told me that my oil pressure sending unit is starting to leak. He told me to go buy one and save it until my next change is due. He said he would put it in while doing my next oil change. My question to my fellow members is, should I worry about this? Would it be harmful/dangerous to wait another 3000 miles until my next oil change to replace it? Thanks!
Ed
Old Sep 21, 2004 | 07:26 AM
Micah95GLE's Avatar
In my experience, those things leak slowly. Just check your oil often to see if the level drops significantly. If it does, then go get it replaced soon. But it will probably be okay.
Old Sep 21, 2004 | 07:29 AM
erty67's Avatar
Decal Specialist
cool...thanks
Old Sep 21, 2004 | 07:43 AM
MaxSpeedSE's Avatar
I went to pep boys ( where i work ) and bought me a bottle of Bars that stops oil leaks....after one oil change all my leaks were sealed, my oil sending unit, and the seal on my pully. Im even running synthedic now.
Good luck
-Chris
Old Sep 21, 2004 | 10:13 AM
mrseed's Avatar
does anyone know the part # for a oil sending unit. i need to replace mine as well
Old Sep 21, 2004 | 10:38 AM
Dreizehn's Avatar
Good luck
-Chris
Id be weary of that stuff. There are tiny passages for oil to travel throughout the motor. How does it keep from sealing those off too?
How's the synthedic working for you?
Old Sep 21, 2004 | 11:15 AM
MaxSpeedSE's Avatar
Id be carful before u buy a new sending unit Mrseed, usly its not the part that goes bad. Its the seal.
Mad max i love it, i switch to moble 1 for about 6 mounths no and no problems. Next oil change im going to try Royal purple. but the moble is good stuff it handels all the nitrous i throw it, and keep the motor cool with the help of some othere secrets
Old Sep 21, 2004 | 11:29 AM
Jatan's Avatar
http://www.motorvate.ca/mvp.php/514
Got mine from AutoZone when mine was leaking. Real easy to replace and only lost a little bit of oil. Couldn't get it off with a wrench so I had to buy the socket for it (I think it was 1")
Old Sep 21, 2004 | 08:26 PM
acj's Avatar
acj
Ed
You "shouldn't" have any problems out of it...as long as the oil isn't pouring out. It's probably just barely seeping and he seen the wet spot. We've replaced these that have been leaking for years, with no other problems than an annoying drip from it.
Old Sep 21, 2004 | 09:04 PM
bearded's Avatar
That thing is like five bucks and takes five minutes to change, its not a big deal. I think the socket I needed to get mine off was 1 and 1/16 inches but to get the new one on was significantly smaller. Don't forget that oil comes out when you take it off....haha we wouldnt want you to get a face full of black stuff.
Old Sep 21, 2004 | 09:05 PM
bearded's Avatar
wait a sec....you dont change your own oil??
Old Sep 22, 2004 | 07:51 AM
sagamax's Avatar
Give me a Bud Light Holmes
how often does this sending unit go bad. a couple times i was low on oil when i was changin my oil but i dont think i have a leak. but at times it was only a quart low and only when i do hard driving. but since then i started using thicker oil and havnt had any problem. i though i was just burning the oil quickly. is this sendin unit something i should check.
Old Sep 22, 2004 | 07:52 AM
erty67's Avatar
Decal Specialist
nope....haven't done that since I was a teenager. It's not that I can't. I'm just too lazy to do it.
....and NO I do not take it to Jiffy Lube. They suck.
Old Sep 22, 2004 | 09:27 AM
bearded's Avatar
Haha yeah for all I know you are like a brain surgeon or something whose time is better spent saving lives....
Old Sep 22, 2004 | 09:33 AM
|Bijan|'s Avatar
UCF Lexus
Are you using synthetic oil erty?
Old Sep 22, 2004 | 12:11 PM
erty67's Avatar
Decal Specialist
Vavoline Durablend (semi-synthetic) .....why? just always have
Old Sep 22, 2004 | 12:54 PM
Nismo3112's Avatar
Custom User Title
Mine was fine, and then all of a sudden it started leaking badly.. Maybe a quart an hour?
Old Sep 22, 2004 | 01:07 PM
Jeff92se's Avatar
I'm needing a caw
I would urge anyone to either buy a new one or reseal the one one. Putting "stop leak" products in the engine is a bad idea.
Old Sep 23, 2004 | 05:52 PM
|Bijan|'s Avatar
UCF Lexus
Well as you probly know, synthetic is thinner than non-syn. I've also got a tiny leak from there too. But I use mobil 1 full syn 10w-30. So, your leak may be a tad bigger than mine.
Old Sep 23, 2004 | 08:30 PM
acj's Avatar
acj
I agree, if you can avoid stop leak...do so. If you have seen some of the engines I have torn apart, you wouldn't ever want stop leak near your car.
Old Sep 23, 2004 | 11:26 PM
guido32's Avatar
My oil sending unit went out a few months ago. I never lost oil, and in a span of twenty minutes, I had lost two quarts. It went from no leak to a bad leak in a span of minutes. I am glad I was in town. My situation was rare, but possible for any other maxima. If you are on the interstate and this happens, you could run out of oil and your light may come on when it's too late. If the sending unit is leaking, change it asap. As others have mentioned, it is cheap and easy. If you don't want to change it, have someone else do it for you. Is the possibility of losing your engine worth waiting?
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
JoshG
51
Sep 21, 2015 10:41 PM
