how to reset ECU
Old Apr 9, 2001 | 02:41 PM
1HOTMAX's Avatar
i am doing the CAI and wonder if i need to reset the ECU. if so how?
Old Apr 9, 2001 | 02:48 PM
mtrai760's Avatar
'Trynna' is not a word
You just have to undo your battery for a couple of hours and it will be fine. Good luck.
Old Apr 9, 2001 | 03:27 PM
1997 Maxima SE's Avatar
didn't work for me
this did thoe http://vbxmaxima.8m.com/ecu.html
Old Apr 9, 2001 | 05:07 PM
DCmax's Avatar
Battery takes too long, do the above.
Old Apr 10, 2001 | 05:55 PM
BrianV's Avatar
http://www.brianv.net/ecu.html
Old Apr 10, 2001 | 06:05 PM
ny96max's Avatar
i say unplug the battery. Im not about to mess with the ECU directly.
1) Unplug the battery for about 2hours
2) re-connect battery
3) start up car (with ALL devices turned off & MOST IMPORTANTLY **DO NOT REV THE ENGINE**
4) let the car idle for about 10min NOT TOUCHING A THING!!
5) turn off the car
MOST CRUTIAL PART:
6) re-start the car and go for a drive around the block, DO NOT BABY THE CAR EITHER, drive somewhat faster than cruising speed. **do not romp on it** this will cause the ECU to reset itself to thinking that you drive that way all the time. Make sure to drive smoothly!
7) go back home....
Old Apr 10, 2001 | 07:10 PM
Sprint's Avatar
if you ever have a check engine light.. try that method .. and you will see that your method doesn't not reset the ECU.. you may think it does.. but in actuallity.. it does not
the ecu reset is very easy.. its easier than unpluging the battery
5) turn off the car
MOST CRUTIAL PART:
7) go back home....
Old Apr 10, 2001 | 07:55 PM
1Phat Max's Avatar
please help
do i need to put the key in the car and have it at on position when re-setting the ecu?please help
Old Apr 10, 2001 | 08:03 PM
Sprint's Avatar
Re: please help
ok now you are just being rhetorical?
do i have to have water in the pot to make steam?
yes yes you do..
you turn the key in on position where the dash lights up.. turn clockwise till it stops count to 2, turn anti clockwise till it stops count to 2, turn anti clockwise till it stops count to 2, turn anti clockwise till it stops
turn the car off and start it up..
boom you are done
Old Apr 10, 2001 | 08:07 PM
Confused's Avatar
Permanent Maxima.org Resident
don't worry about it
you need to remove the battery to do the cai install... jus take your time.
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
cruce91
Sep 20, 2015 10:23 AM
Colossus
Sep 9, 2015 05:46 AM
