Hello there!!
Today after waiting for so long... i finally lower my car. 2.2 n the front and 1.8 n the rear.... car so super cool, but for months now i have had a problem starting my car. I would have to giggle the key up and down for the car to finally turn on. Today at school the car wouldn't start... it seemed like the battery was low. so i went ahead and got another battery. Now it's night time and the car wont turn on with the key. I would have to push the car to turn it on. At this point i know it's not my alternator, battery. Im not sure about the starter, but when i twiste the key it doesn't seem to be wanting to turn on at all. Please help me fix this problem. The car looks great, but it wont turn on :.(
Quote:
That was the first thing that came to my mind, but the car would sometimes turn on, but just very very slowly or weak. That's why i didn't think it was the switch thank god i have another maxima. Tomorrow im gonna take that part out and see if it works...... but if you guys think it could be anything else please let me know ... thank you very very much guys... i'll try to post pics of my dropped.... it looks awsome Originally Posted by nostrixoxide
i thought this happened because you drop your car. It could be your Starter going bye bye.
Mine does it too...oh you can teach yourself to start it, but I'm thinking I don't want this security feature....mine and my friend's car have the same problem. Where can I get this ignition switch? Btw. Turn key forward into 1st notch, then from there forward and hold...should do the trick.
Im not sure either but my friend has 96 Max (That just got ****ed up buy the way. SOme guy U-turned into him ouch...) but ya anyways. He only had 60k miles on the car but his ignition coil went out about 58k and his starter went out at 60k.. So nto sure. Fixed the problem though. Starts up faster than my moms ****ing 04 BMW. jeez...
Quote:
Originally Posted by nismology
Probably the ignition switch.
....has nothing to do with lowering itMember
Mine was starting to do the same thing at first i thought it was the battery because it sounded like it didn't have much power. After switching batteries I found out the bendix in the start wasn't wanting to engage all the time, went to O'Riellies and got another one for $50. haven't had a problem sence. before mine went out it seemed like it was taking longer to turn over then before, has it done that to you?
my ignition switch has been replaced also but at times when i return to my car after class at times the car won't turn over... it takes a bit longer than usual at times.
Quote:
What do you mean turn over? and what was the part you bought? can i get it at the nissan dealer and how hard is it to install it? I just finished changing my switch and sadly my car still not starting. I'm guessing is not the started b/c the car wont try to start at all. there's no click click click....man this sucks..... i wanna take my car out for a ride, but can't b/c it wont start.... well only when i pussh it Originally Posted by chancy31
help me.... thank youI have a CEL 04-07 which is Crankshaft Position sensor could that have anything to do wiht my car not wanting to start at all? PLEASE GUYS IM DYING HERE
Quote:
Sounds like you have a compound problem. A failed Crank Position sensor will prevent the car from starting, but it wont keep it from turning over. Something else is causing that.Originally Posted by mAxPwEr4Us
It could be the ignition ______(don't know the name of it off hand) that comes off your ignition lock. This thing is used to turn on all the avaliable circuits in the car. This thing is located on the left side of the igintion lock(opposite side of where you stick your key in to start the car). It's probably worn out from excessive use. I had to replace mine when I couldn't get the car to start.
Hello!
Thank you for all yoru replys.... I FINALLY got the car to work
it was the starter, but im glad i changed the ingition switch b/c now i dont have to jiggle the key to start the car. Car is running great.... looks a lot better and im happy...
Once again thank you guys for all the input...
Peter
Once again thank you guys for all the input... Peter
Peter
A dead starter will not make your car start, A dead Ingition switch, nothing will come on when you turn the key to on position.Originally Posted by mAxPwEr4Us
Hello!Thank you for all yoru replys.... I FINALLY got the car to work
Quote:
You forgot to mention how a faulty starter solenoid may work intermidantly when they start to go bad?Originally Posted by CystumMax
