agx's squeak, way to stop?
Old Sep 26, 2004 | 05:58 AM
nick1020's Avatar
Whenever the temp falls below 50 degrees my front agx's make a squeaking noise every time I hit a bump. Is there a way to stop this or do I have a bad pair of agx's?
Old Sep 26, 2004 | 08:58 AM
deezo's Avatar
One of my fronts started to sqeak. I'm not going to figure it out, I'm just going to replace it with Illuminas.
Old Sep 26, 2004 | 09:20 AM
stephenlc's Avatar
Its because they are liquid filled. Once they heat up it will not make a noise.
Old Sep 26, 2004 | 10:12 AM
sagamax's Avatar
Give me a Bud Light Holmes
i noticed my gr2 squeak too but its not bad at all it is just his high pitch squeak that really isnt noticable. i will eventually upgrade to agx or illuminas
Old Sep 26, 2004 | 11:46 AM
KLiNkER's Avatar
my GR2 squeak a bit too i'll try to figure it out but I don't like any noise that is not supposed to be there so if i manage to fix it i'll let you know.
looks like KYB is the problem
Old Sep 26, 2004 | 12:08 PM
1996blackmax's Avatar
Go with the Illuminas. Take it from someone who's been riding on AGX's for 19 months.
Old Sep 26, 2004 | 04:13 PM
njmaxseltd's Avatar
Are you sure it's the strut and not a bushing? Squirt some WD-40 onto the strut piston and see if the squeak stops. If it doesn't then you should look at your control arm and sway bar bushings.
Old Sep 26, 2004 | 04:36 PM
Guinader's Avatar
how about the squeak on stock suspension? dw-40 works???
D Mason
Jun 21, 2016 04:43 AM
maxima-junky
Oct 7, 2015 06:13 PM
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
