a fresh alignment every day!
Old Sep 26, 2004 | 07:57 AM
thisisausername's Avatar
well...I do quite a bit of hard cornering during my daily joyriding sessions. Lately I've noticed that every time I take a hard left/right my alignment gets a brand new adjustment. Sometimes my car goes straight, sometimes it veers to the left/right. Sounds like something is loose/messed up, anyone have ideas?
Theres also this groaning noise that comes from somewhere in the rear during cornering and after the car is off and sitting for a min. Not sure what it is but it doesn't sound good. Sounds like metal rubbing sort of... Maybe a strut needs some lube?
Might as well throw about my question about ideal shift rpm's too... How high can I rev when doing a normal acceleration without hurting the car?
I have a 4th gen 96 max se
Old Sep 26, 2004 | 08:09 AM
Assassinroon's Avatar
Originally Posted by thisisausername
Theres also this groaning noise that comes from somewhere in the rear during cornering and after the car is off and sitting for a min. Not sure what it is but it doesn't sound good. Sounds like metal rubbing sort of... Maybe a strut needs some lube??
hey yo this happens to my car too any ideas on what it is ?
Old Sep 26, 2004 | 12:41 PM
SkinnyMax's Avatar
maxima no more
first thing I would check would be your tie-rod ends, jack up the car and check for play by moving the wheel with your hands back and forth. as for the noise in the rear, it makes noise when the car is off? and for shifting, you won't hurt the car if you keep it below redline, but for normal everyday driving I shift at 3-4k depending on situations.
Old Sep 26, 2004 | 01:01 PM
gtr_rider's Avatar
192.168.1.1
check to see if your control arm bushings arent shot. I used to have the back and forth movement when I accelerate and let off the throttle. Turns out my VC oil leak ate through my bushings.
Old Sep 26, 2004 | 04:09 PM
njmaxseltd's Avatar
Lose Rack & Pinion mount bushings will cause the rack to move under the force of a hard corner. It's often moves back on a turn the opposite way. Were starting to see a few of the older 4th gens have this problem. It's probably not such a hard job to replace them either.
Old Sep 26, 2004 | 04:19 PM
gtr_rider's Avatar
192.168.1.1
Tom, do you have a picture of this rack and pinon bushing? I was told I needed to change it at the dealer, but havent had any problem sinceu I changed my control arm ones?
Old Sep 26, 2004 | 04:56 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
yeaah I'm having the same problem and I got the same explanation tom just gave. Pics would be awesome too.
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
