Strut replacement parts questions
Old Sep 27, 2004 | 01:39 AM
haysdb's Avatar
I will be installing new springs and struts on my 98 Maxima (95K miles) and have read that I should replace some other parts as well, such as the strut mounts, front strut bearings, and dust boots.
I can understand replacing the bearings, but why should the mounts need to be replaced?
All I can find online are the KYB bearings. Are the KYB bearings just as good as the OEM bearings?
I cannot find the darn dust boots anywhere except Cattman.com, and I am having difficulty accessing their order page. Why would such an item be available from only ONE source?
Am I missing anything?
Old Sep 27, 2004 | 02:54 AM
happyricefob's Avatar
V^___^V
www.tirerack.com has KYB dustboots/strut mount.
u don't necessary need to replace them..unless they are worned out.
Old Sep 27, 2004 | 05:07 AM
haysdb's Avatar
Tirerack has a PICTURE of the KYB dustboots, but I have not found a link to click to actually BUY them. There is a link "Strut Boots/Mounts," but when I drill down, the only options I get are for the strut (front) and shock (rear) mounts.
Old Sep 27, 2004 | 05:11 AM
V^___^V
http://maxmods.dyndns.org/index.php?MaximaHandling
Old Sep 27, 2004 | 07:35 AM
haysdb's Avatar
I know that page, but completely overlooked the MaximaDustBoots link.
My OEM dustboots are cracked and split at almost every single crease, so I am definitely due for new boots.
So, are Nissan OEM parts not available online, or am I just not looking in the right place?
Old Sep 27, 2004 | 07:57 AM
njmodi's Avatar
Do I get a tax break?
Go to courtesyparts.com or jrnissanparts.com - if you can get the parts online, just call those guys - they have everything you need. Do your research before using KYB strut mounts - a lot of org'ers have had premature failure of these parts. When I replaced my struts, I just replaced the strut bearings, spring isolators and strut boots. My mounts were fine. Mounts are not that cheap - only replace them if yours are showing signs of wear/failure.
CRizz
41
Jun 7, 2021 05:42 AM
doobadoo
Aug 15, 2015 06:43 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
kirkhilles
Aug 8, 2015 10:53 AM
laparka66
Aug 6, 2015 09:36 AM
