power steering noise....help!
Old Sep 27, 2004 | 10:02 AM
johnmadmax's Avatar
Hello all,
Does anybody had this problem? My 97 Max started with a noise like power steering fliud was missing, I checked and filled it up and noise still there. I took the car to Firestone did alingment and they couldn't find problem but they said that I need to replace Power steering pump....BS The noise is a pain...anybody with any ideas what could be wrong?
Old Sep 27, 2004 | 10:56 AM
f550maranello2's Avatar
does it make noise when u turn the wheel, cuz if it does u probably need to replace it
Old Sep 27, 2004 | 11:02 AM
s0ber's Avatar
Check the idler pully(tensionor), maybe the bearings are bad, Mine was bad and a shop thought it was the PS Pump, but that was BS It was the $40 pully that I replaced myself..
Old Sep 27, 2004 | 11:38 AM
johnmadmax's Avatar
Thanks!...do you know where can I find information How to replace that pully?
Old Sep 27, 2004 | 11:40 AM
s0ber's Avatar
Well its pretty simple after you look at it, a bracket holds it just loosen the tension and remove 2 bolts (2 or 3 dont remember) and the thing will slide off..
Make sure its that first, use a screwdriver in your ear and put it on it or something, whatever works
Old Sep 27, 2004 | 11:43 AM
97GLE's Avatar
Well be carefull with this one... I had a bad alternator, but I could hear the sound when I put a screwdriver on the PS Pump and it changed pitch distinctly when I turned the wheel. I almost replaced it, until I noticed the sound also changed with the headlights. Only way I figured out it was the alternator was to put a charger on the battery while the engine was running which took the load off the alternator and the sound went away.
lowpost99
Oct 26, 2025 06:53 PM
Fbana41
Aug 29, 2016 12:18 PM
rbarnes
Dec 31, 2015 06:29 PM
Mochedda
Dec 15, 2015 11:27 AM
fastcarny
Oct 12, 2015 07:06 AM
