Did anyone here changed thermostat ?!?
Old Sep 28, 2004 | 03:22 PM
flthere's Avatar
I guess I have to do it now and was trying to see if anyone did or got it done ?!?
Old Sep 28, 2004 | 03:26 PM
Ant96GLE's Avatar
Yea I dun did it, why?
Old Sep 28, 2004 | 03:30 PM
tutu's Avatar
I have a problem with the engine idle speed. When I start it in the morning, the idle rpm stays at 1,500. After I drive it for a while, I start it again the rm lower to 600~700. A mechanic told me that I need to change the "head" temp sensor. Is is the same thing with themostat?
Old Sep 28, 2004 | 03:33 PM
KLiNkER's Avatar
my ECU throws me Engine Coolant Temperature Sensor code is that the same? if yes... where is that sensor located heh
i got a knock sensor on ebay from yoshisomething (the one who was recommended here on the org he put up 12 KS this morning) and ill probably open the hood only once
Old Sep 28, 2004 | 06:34 PM
flthere's Avatar
http://forums.maxima.org/showpost.ph...4&postcount=43
Eng. temp needle shot up in my car and seems like the thermostat is the culprit .. no codes, it gave 0505 which is 'no failure detected/recorded" .. there is coolant in there, the fans are starting normal ... no leaks and so no problem with hoses ... radiator is fine ...
dealer asked for $220 to change the thermostat
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
Noela
Sep 26, 2015 08:22 AM
