anyone got a jwt ecu?
Old Sep 29, 2004 | 06:46 PM
wickedreaper's Avatar
anyone got a jwt ecu?/has anyone had trouble with sensor errors or the check engine
I am thinking of getting this upgrade and would like to hear from someone who has done this,so i would really know how well it works.
Old Sep 29, 2004 | 08:00 PM
Nealoc187's Avatar
SLOW
lots of people have them, and they are awesome. they are almost as good as adding a ypipe.
Old Sep 29, 2004 | 08:42 PM
2k2-blk-6spd's Avatar
My friend has one in his '95 and he LOVES IT! I'm talking he REALLY loves it. The raised rev limiter alone makes this mod worth it but it also adds quite a bit of HP so I'd definitely recommend getting one.
Old Sep 29, 2004 | 09:47 PM
DAVE Sz's Avatar
Hooooooonda.....
Doesn't really add "quite a bit of HP".
Old Sep 29, 2004 | 11:13 PM
global_threat's Avatar
10-15hp throughout the midrange rpm's isn't "quite a bit?" sorry if i beg to differ.
and to the thread starter, definatly grab one. they're expensive, but definatly worth it - as was said above, the raised redline is damn near worth the cost by itself.
Old Sep 29, 2004 | 11:19 PM
tedo007's Avatar
faster than you think
when somebody gonna do something about 99 ecu ahhhhhhhhhh
Old Sep 30, 2004 | 06:32 AM
Micah95GLE's Avatar
Originally Posted by slammed95
my G-Force ECU added 14hp and 17ft-lbs,
Is that BHP or WHP? Do you have dynos to post?
Old Sep 30, 2004 | 07:04 AM
krismax's Avatar
Father of the 00 VI
I felt no increase at all and my timing continues to go toward 0 . Somtimes if i catch it right my car feels exremly fast or very slow 65% of the time.
Old Sep 30, 2004 | 09:00 AM
chuckie311's Avatar
jwt and technosquare said they cant do anything about 99 or 98 ecu. you have to get a 96 ecu and run it in the 99. just have to do a a few wires swaps on your wireing harness to get it to work..
Old Sep 30, 2004 | 06:01 PM
Thanks for all the feedback,but now i have a second question.
Has anyone with this ecu had any trouble with the check engine light,
or any other sensor errors after installing this ecu?
Old Sep 30, 2004 | 07:14 PM
Zipp028's Avatar
how long does it take to get a jwt ecu back?
Old Sep 30, 2004 | 07:31 PM
chuckie311's Avatar
2 damn long i have heard month or 2
Old Sep 30, 2004 | 10:54 PM
tedo007's Avatar
am i going to get any CEL if i replace mine with 96???
Old Sep 30, 2004 | 11:59 PM
SPiG's Avatar
SomePsychoGuy
http://maxmods.dyndns.org/index.php?MaximaEcus
...FAQS
There should be no CEL for a 95/96 while there may or may not be one for a 97-99. For you 99 ppl talk to JWT b/c I think that they can mod a 95/96 ECU to work with at least some 99s. JWT has a longer wait period than TS but is more flexible with different MAF, injector, and the all important redline for those with MEVI or -K manifold swap. Research a little more and the best first mod is most likely a y pipe and then maybe suspension or intake or something. ECU works well with other mods especially some kind of Variable intake manifold.
thx
Old Oct 1, 2004 | 08:20 AM
Dave B's Avatar
Not DAVEB the parts guy
I love my JWT ECU and I wish I would have done it years ago. The extended redline is fairly worthless if you have the stock intake manifold, but if you are boosted or have the MEVI, it's the only way to go. This is defiinitely one of the best NA mods you can do if you own a 95-97.
Power from idle to 3300rpms is unchanged, but from 3300 to the fuel cut, there is a healthy bump in power. Nothing huge, but the power curve overall is raised which equals a decent drop in 1/4 mile. If you never plan on getting the MEVI, then try the cheaper G-force ECU. It does the same thing except raise the redline.
Old Oct 1, 2004 | 03:10 PM
SlackR237's Avatar
Rollin' on 'Caps
I'm thinking about getting this mod, but I want to keep my Maxima in good shape for a long long time, is the advanced timing any harder on the engine than the stock ECU?
Old Oct 1, 2004 | 03:27 PM
speedemn's Avatar
Here's a dyno for you... the only difference between the two graphs is the JWT ECU (this is post MEVI, y-pipe and all those goodies of course). This should give you a very good idea of exactly what the JWT ECU does on its own. http://forums.maxima.org/showthread.php?t=331053
As for compatibility, since you have a 95, you have nothing to worry about. What I did was pick up another 95 5-spd ECU and sent that one in to JWT. So I have my stock one as a backup too. If you are automatic, keep in mind that you will have to manually shift, to take advantage of the extended rev limit because the transmission computer will still want to shift at 6200 or whatever the stock shift point is when the shifter is left in 'D'.
As Dave said, getting the JWT ECU which will extend your rev limit is pointless unless you have the MEVI too. The Technosquare ECU would be a better choice for you if you plan on sticking with the USM.
Old Oct 1, 2004 | 08:58 PM
AsthmaMax11's Avatar
I have the MEVI and JWT ECU. The ECU is very much worth it. The midrange that I lost through the MEVI is almost back but the power above where my VI kicks in is fukking awesome. Shifting with the extended rev limiter puts 2nd gear at the hot spot for the MEVI to kick in. Everything is much smoother than with just the MEVI.
I don't take it to or past redline very often though....
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
t6378tp
Sep 29, 2018 04:27 PM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
