HELP! Max won't start. ECU codes 0403 & 0101
Old Sep 30, 2004 | 08:43 AM
Stromax2's Avatar
My 97 Max won't start and the codes I get are 0403 (Engine Knock sensor) and 0101 (Camshaft Position Sensor). I know where to locate the Engine Knock sensor but where is the Camshaft Position Sensor? How should I proceed?
StroMax2
Old Sep 30, 2004 | 09:55 AM
MaxedOutOfCash's Avatar
Pizda Boy
It is on the engine front cover ... when looking at the oil cap, work your way down...it's right there...(i'll snap a pic for you later on)
this may sound stupid but it is probably your starter that is malfunctioning... what does the camshaft position sensor have to do with the starter?
According to the Factory Service Manual, if you get this code and your ending DOESN'T start... you should look into the electrical system (starting system to be exact)...
and when I looked at that, it points to the starter being either bad or malfunctioning... (fixable I guess if you want to take it apart)
Sam
Old Sep 30, 2004 | 10:08 AM
Pizda Boy
ALSO: the knock sensor code is probably just showing up because of the camshaft position sensor...so don't go buying a new KS just yet... fix this first & check the codes to see if your KS is showing up then...if it is then replace... but chances are that it will disappear (it likes to do that)
Old Sep 30, 2004 | 10:25 AM
Stromax2's Avatar
MaxedOutOfCash,
Thank for your help so far. currently the car turns over but doesn't start.
Old Sep 30, 2004 | 10:26 AM
Pizda Boy
it will turn over but it won't engage the fly wheel... (therefore it's bad)
how many miles you got on the max???
Old Sep 30, 2004 | 10:28 AM
Stromax2's Avatar
Miles on Max = 138500
Old Sep 30, 2004 | 10:34 AM
Pizda Boy
Definitely check out the starter.... starters going bad is common in our maximas... especially at this mileage..
Old Sep 30, 2004 | 10:35 AM
Pizda Boy
oh and don't forget to let us know if it actually WAS the starter when you get it fixed.
Old Sep 30, 2004 | 10:53 AM
96pearlmax's Avatar
I had this same problem, exactly. I was told by many org members that my starter was going out. My ECU was showing camshaft sensor. I replaced the sensor and it has been good as new. The camshaft sensor throws of the timing of the starter somehow. I picked up a new camshaft sensor from NAPA for 53 bucks and it took 2 minutes to replace it.
Old Sep 30, 2004 | 11:07 AM
Stromax2's Avatar
This sounds like the cheapest place to start, with the camshaft position sensor.
Old Sep 30, 2004 | 02:21 PM
Stromax2's Avatar
MaxedOutOfCash & 96pearlmax,
Thanks for the help........replaced camshaft position sensor...started right up
Old Oct 1, 2004 | 05:35 AM
Pizda Boy
sounds good....
i need to remember that....
darn FSM ...misguiding people
Old Oct 1, 2004 | 05:39 AM
Pizda Boy
BTW: did the KS code disappear?
Old Oct 2, 2004 | 01:13 PM
96pearlmax's Avatar
No problem. Many people think that there starter is going out but most of the time, its a sensor in the electrical system throwing things off
Old Oct 3, 2004 | 03:39 AM
Stromax2's Avatar
MaxedOutofCash,
Yes the KS code disappeared
mvm062
Nov 30, 2020 09:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
captchaos
Mar 15, 2016 12:18 PM
markevans999
Sep 10, 2015 04:29 PM
MaxLife17
Sep 8, 2015 02:36 PM
